Listening to XB10 via balanced to Angies, source is LG V20 via aptX HD and Spotify at extreme streaming.
I'm impressed, mightily impressed.
No one has so far mentioned the DCT filter option in the XB10 ?
Radsone DCT (Distinctive Clear Technology™)
You can turn it on and off, it's something that LG also uses. The company is called Radstone
i bought the sony 1000x to pair it with my lgv20.. if this combo is that good with tidal, I am doing a 1 day shipping and returning the sony now and will try this with my layla and ether c 1.1. lol
Does the 1000x have aptX HD? I think it only has LDAC so you're only getting 'regular BT' with the V20 - which doesn't sound great.
It has aptX
AptX HD is useless on AK players. Max 1 metre, with cutouts. 20cm with no signal cut outs, but only if you have no other wireless things around, and you don't move too much flesh around the device.
...Apt-x HD requires a specific chipset (CSR8675) which is why most older apt-x only devices can't be upgraded...
...With their latest firmware update AK has made the AK3xx series units unable to stream Bluetooth to any device that does not have aptX HD capability....
Hmm....I have tried an AptX Sony headset, the MDR-1000X with the AK380 with 1.40 firmware and it's fine. On the AK380 screen aptX appears. I then try the XB10 and aptX HD appears on the AK380 screen.
I also have no issues with range with the AK380 being on one side of the room and the XB10 on the other, 20 feet away...no break-ups.
...Recently I've tried XB10 with Windows10 notebook (as W10 is supposed to support AptX) and though the setup was working fine the sound was flat and lifeless. I was suspecting that there is no aptx codec in use and I was right. After some googling I've found that if you have Intel bluetooth card/solution/all-in-one in order to be able to use AptX you HAVE to use Intel provided bluetooth stack - basically you need to install Intel drivers from their site replacing Windows10 defaults...
@WAS55 mentioned your post in another thread which raised my interest in terms of the AK3xx / AK370's own BT chipset. I assumed that A&K had older chipsets but was surprised when they recently changed their website's specifications for these DAPs from "AptX" to "AptX HD". So I went to their FB site and simply asked if the AK3xxs have the 8675 chipset. They replied with a "yes". Due to the official release from Qualcomm and the release dates of the AK3xx's I found it hard to believe and I will take their confirmation with a grain of salt. The only way to confirm is listen for differences I guess. @jonstatt below showed that the new AK3xx FW "confirms" an AptX HD connection ...when A&K's own device (XB10) is connected. I'd like to see someone connect anything other than the XB10 to an AK3xx and also see it return an "AptX HD" confirmation. That or if anyone wants to open up their AK3xx to confirm the chipset in use...
Just to reiterate that along with WAS55 we managed to clarify on the 320 thread that this is not [always] the case as my really old BT 3.x AptX headset connects to my AK320 w/latest FW just fine:
...On android you can check if aptx is in use by using logcat...
Afaik, the AK3xx devices are among the only portables that confirm whether apt-x (incl. HD) is active. Last time I tried confirming aptx activity on my phone it involved checking logs from the phone's bluetooth stack...
It's all good and well that the AK3xx can "identify" a call from a AptX HD device, but this alone in no way guarantees that the AK3xx will actually operate in AptX HD mode... . As you (and many others on the Internet) pointed out, the CSR8675 is a requirement for AptX-HD support...
