- Aug 9, 2006
Sound quality update:
First--using a 7th gen iPod Nano as the bluetooth source (BT 4.0, but no aptx) there is a hit to SQ. The balanced connection mitigates it somewhat, but to me, it's not enough. The SQ isn't bad exactly, it's more like an absence of good. That's disappointing, the iPod nano + hockey puck combo would be an attractively small mobile setup. But I'll add more thoughts about that below.
I currently have an HD800 hooked into the balanced port, and thus I've located the puck's limits. It sounds good, sure, but it's not a particularly exciting variety of good. It's not eargasm level good, while every other set I've tried [with a balanced connection]. This seems to be an issue with the amp as much as the source signal. I say this because I've noticed that cheap amps (like the Fiio E11, for an example) can make the HD800 borderline painful to listen to, after even short 15 min sessions at moderately loud levels. In contrast, the amp in my Geek Out V2+ can push them quite loud without me feeling any discomfort whatsoever! The XB10 is really somewhere in-between the two.
So far for me, the PSB M4U 1 is the ideal partner to get the most out of an aptx connected XB10. The M50 vibrates too much with the bass, and yes I realize what a wonderful problem that is to have, as far as problems go. I also must mention my vintage Pioneer SE L40, for being eargasm inducing even through theXB10's SE port!
After one day of ownership I am absolutely thrilled with this purchase. My biggest complaint is thatnif you accidentally sit on it while it's playing, there's a strong likelihood that you'll turn the volume all the way up and hurt something in your ear as a result!
I'm considering trying to pick up a small used Android phone (of nearly any make/model) to use as a portable digital transport. It would require aptx and full USB audio support, and will probably be much less expensive than my ipod, which I'm selling in order to support this notion. Which in a way brings me to the last thing I want to say, the best thing about the XB10:
As great as it can sound now, we still aren't at it's true limits yet, as I haven't even seen a review using aptx HD! The future is looking bright at the moment.
By the way, you can put the hold button on and protect your ears. I also put it in my back pocket.
