Astell & Kern SR15: A&norma Impressions & Reviews
post-14775054
Post #1,246 of 2,434
Irvine, CA
Irvine, CA
Thanks Jason.
The Qobuz app for Android is also a work in progress. As they release new versions to optimize it and make it more efficient, you will probably see better battery times. There were a few previous versions that were not optimized and there was greater battery drain seen when using it.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
post-14775070
Post #1,247 of 2,434
Shinobi70
Slovenia
Slovenia
Yeah, I get about 6-7 hrs on balanced, volume 60-70, playing mostly 24.96 flacs and wavs. WI-FI turned off and not much screen time.
I should test playing 24.192 files as the SR gets a bit warmer then. So it's safe to assume it will affect battery drain..
post-14775512
Post #1,248 of 2,434
JTori
Michigan
Michigan
I decided to take the plunge on a pair of AK T5P Special Editions to mate with my SR15. I can say that the care by Beyerdynamic in tuning these to AK's house sound has paid off. They are a magical pairing with the SR15. And, easy to drive, preserving battery life.
Here's an image:
post-14775535
Post #1,249 of 2,434
abitdeef
Formerly known as ihatepopupads
Here's an image:
Are they as comfy as they look? I’m convinced of their Tesla tech after using the akt8ieii. That’s a lot of bread though :) I’ve heard the hd 660s and they sound great. Those come with a balanced cable right?
I’m assuming you have been listening balanced. Can you give a quick summery on the sound sig?
post-14775594
Post #1,250 of 2,434
JTori
Michigan
Michigan
They are comfy. And, light. They're expensive though; it hurt just a little (maybe more) to buy them. I knew, however, I'd end up purchasing a case and balanced cable and factored this into my decision. I also wanted to use them with my Bottlehead Mainline. As a result, I ordered a 2.5mm TRRS-to-XLR adapter. One thing I have to note: The packaging was not what I would expect from such an expensive, presumably exclusive and German product. The case is floating around in the box with no plastic bag to protect it and the 3.5mm adapter is loose inside the case. By way of comparison, the adapter I referenced was encased in a ziploc bag, inside a Pelican-like box, inside a ziploc bag, inside a fitted bubble-wrap bag. Maybe a bit of overkill, but it was a $38 item. Or, compare this to Oppo, who know how to deliver customer experience. Can't complain about the phones, though. They sound amazing!
Reactions: abitdeef
post-14775674
Post #1,251 of 2,434
abitdeef
Wow is that the cable they came with? Nice:)
post-14775690
Post #1,252 of 2,434
JTori
Michigan
Michigan
Yes, it is. It’s one of the reasons I opted for the Special Edition. Figured I’d end up buying something like it anyway. There’s detailed info on AK’s website about the phones and cable.
post-14775700
Post #1,253 of 2,434
abitdeef
Thank you!
post-14775747
Post #1,254 of 2,434
gunwale
I am starting to prefer the sound from SE compared to balance for iem.
I think the balance goes loud too quickly while the volume of SE can be fine tuned.
post-14775811
Post #1,255 of 2,434
atmasphere
New York
New York
So I've been playing with mine between Campfire Comet IEMs in balanced mode (Fiio cable) and Sennheiser HD6XX SE mode. I just switched the Campfire cable back to the stock SE (copper Litz) and I can't believe how much better things sound. The stage is considerably wider and tonally deeper now. I don't think this is a balanced vs SE detail as much as the quality of that fiio cable which I think was about 30 bucks. I honestly feel as though I am listening to different headphones right now.
post-14776212
Post #1,256 of 2,434
gunwale
I had the exact same experience as you. I too swapped back to stock ofc cable and everything became more articulated.
I think sr15 loves copper more than silvers.
post-14779978
Post #1,258 of 2,434
atmasphere
New York
New York
Today my balanced cable for the HD 6xx arrived and aside from a quick test on the mytek brooklyn dac+ (amazingly good) I also used a 4-pint to 2.5 cable to test the SR15 and it's super sharp this way. While not practical in a truly mobile context, it's pretty great for moving around the house. There's much more presence and depth to the sound ... seems like the SR15 can really drive it up as much as you can offer. So happy with this purchase!
post-14781004
Post #1,259 of 2,434
abitdeef
Came to my senses :wink: it does sound better than es100 and it’s the perfect size:)
Reactions: pilgrimbilly
post-14781330
Post #1,260 of 2,434
nicodem
Warsaw, Poland
Warsaw, Poland
Any info what exactly comes corrected in new 1.14 firmware that was released yesterday?
Reactions: JeroenTop
