Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
8 9 10 11 12 13 14 15 16 17
  1. JasonNYC
    Tidal Masters uses MQA, which our players currently do not support. We are looking into offering MQA in the future, but have no ETA on when it may be added. Once MQA is supported, Tidal Masters will be supported.
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  2. schleppsound
    Now - my understanding is that Tidal Masters is only available using the desktop Tidal client - not mobile/portable as of yet ...
  3. JasonNYC
    It is slowly making it's way out to portables. The ACTIVO CT10 hi res player, which is a collaboration with AK does Tidal Masters.
  4. mmu16
    Its ava
    Tidal masters is available on many network streamers. My plan was to update my existing AK120 mk2 which i regularly use as a streamer (unfortunately NAS only). Looks like a Bluenote 2 might be the go here.
  5. CybrSlydr
    How does this compare to the Kann specs-wise? I'm still a newb at audio bits.
  6. JamesAnthony
    sorted.
  7. JasonNYC
    @JamesAnthony
    Try running a manual media scan. They may not have indexed correctly on the player.
    Settings, system reset, Initialize media scan. If you have playlists created, make sure the clear playlists box is NOT CHECKED. It usually takes a few minutes, but can take up to 15 minutes depending on how many files are in internal and external memory.
  8. KuroKitsu
    2 questions:
    Anyone try this out with sensitive TOTL IEMs? Is there any hissing at all?
    I took a look throught the manual to see if there was an option to adjust amp gain but didnt see it at all. Is this an option?
  9. ce3eoa
    The Pioneer XDP-30R and the Onkyo DP-S1 portable Daps, which are exactly the same, stream Tidal Masters
    mmu16 likes this.
  10. cleg
    my subjective video about SE15
  11. Marcellus1980
    Great review! Do you have an opinion on the balanced 2.5 vs 3.5 sound quality? I've used both, but for some reason am drawn to the 3.5 sound over the 2.5.....
  12. cleg
    well, at first impression, they seemed pretty similar to me. but I don't have my switch for A/B testing, probably with it I'll get more detailed impression
    Marcellus1980 likes this.
  13. Mark2010
    It's not good for the battery to be heating up!
  14. ce3eoa
    There is a new firmware, i corrects some performance problems, now it is more stable, the upgrade was done connected to wifi, well done A&K
  15. WayneWoondirts
    szore, HamsterKing and Ultrainferno like this.
