Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
55 56 57 58 59 60 61 62 63 64
66 67 68 69 70 71 72 73 74 75
  1. JasonNYC
    @nicodem I have been testing the SR15 in DAC mode with Windows 10 the past few days and have been unable to replicate using a number of different Windows music players and a variety of files - FLAC, DSD, ALAC, ACC and MP3, all various bit rates. Can you please let me know what programs you are using that you notice the clicks and pops?
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  2. JasonNYC
    @nicodem I am using the latest firmware - 1.13 and Windows 10 Pro version 1803.
  3. nicodem
    Actually any sound and any program. Even when you launch YouTube - you got pops and clicks for few seconds, then it stabilizes itself. Pretty sure this is a buffer thing.
    Are there any drivers available? ASIO, anything else I should install?
  4. nicodem
    Windows 10, 1809 version, SR15 - 1.13 firmware
  5. -Kenny-
    The first thing i thought when using my sr15 for the first time was: i wish they made this thing a little bigger so it had a bigger battery and bigger screen. The tiny size makes it look way cheaper and toy-like than it actually is imo.
    bgtip likes this.
  6. Tsukuyomi
    How much battery are you getting on a daily use?
  7. -Kenny-
    I've never drained it completely. I've only used it at home untill now so i charge it regularly. But the battery drains a little faster than i'd like. I don't think i would get much more than 5, 6 hours. Nothing abnormal probably. Just wish they fitted a larger battery.
    bgtip likes this.
  8. abitdeef
    You using balanced and WiFi, and do you use your screen a lot? That’s what I get if I’m using balanced and WiFi a bit. Normally I get about 9-10 hours.
    I’m using SE and I hardly use the screen. Those are estimated but probably pretty close. I might do a battery run down test. And standby draining is really good, very minimal, unless you have WiFi on and then it goes down fast even in standby.
    bgtip likes this.
  9. -Kenny-
    Yes, mostly tidal and balanced. It's not that huge of a problem. Just a thought.
  10. abitdeef
    Yes I agree it could be better, but pretty normal under those circumstances. And the compactness is one thing I love about SR15.
  11. singleended5863
    It is light weight and sit in my hand perfectly. I like very much the tilting screen.
  12. bgtip
    It is a huge problem to me because I travel often. In my view SR15 sounds better with balanced cable. At least I think I can hear the difference with my FiiO FH5. So why should I use the SE cable just to spare some battery? I would have never sacrificed sound quality. On a 12 hrs trip with two flight changes I felt very uneasy about the battery depletion rate. And I used my power bank too.
  13. -Kenny-
    I certainly agree, in your case it's a problem. That's why i think for that price they could have included a bigger battery and screen. Not huge, but a bit bigger so it was more "best of both worlds". Now i feel like it was almost made too small, sacrificing battery life.
    But i understand that for others the small size is just what they like about the sr15 too. I guess you just can't do right for everyone.
  14. emrelights1973
    how is the SP1000M battery life.... it is small as well
  15. dakchi
    I have both SP1000M and SR15. Surprisingly, the battery of SR15 charges quicker that SP1000M although it does not have quick charge. I also have the impression that battery drains faster in SP1000M, maybe because of bigger screen; but if you don't use the screen at all, SP1000M should last longer
    bgtip likes this.
