Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
54 55 56 57 58 59 60 61 62 63
65 66 67 68 69 70 71 72 73 74
  1. T.R.A.N.C.E.
    From what I gather it doesn't bypass the amp, but it still works flawlessly with external amping since the amp stage is particularly clean.
    329161 likes this.
  2. gunwale
    I just updated my open tidal to 2.11.x the scroll is lagless now. 2.9 is extremely laggy.
  3. 329161
    The line out feature seems a bit redundant. Functionally and sonically it seems identical to normal playback mode.
  4. ToddMSP
    Their response "And it works" is disappointing at best.
    I am a Mac user and am not able to save playlists as described from the HQ team. Seeing other comments and videos on this topic (Thanks to JeremyLaurenson for the detailed background on this issue) it appears that the AK Dev team is not testing properly on the Mac platform.
    However, if the intent is that Mac users are not going to have the same functionality as Windows then I bought a portable from the wrong company.
    Please advise on what AK's intentions are. If Mac is not going to be supported then I expect to be able to return the product for a full refund.
    Thanks
    Todd
    ThomasCGN likes this.
  5. nicodem
    Hi
    SR15 and Windows 10 - no drivers needed, sound goes but until it fills buffer (few seconds) you hear clicks and pops. On every track or at every rewind/forward. Clicks&pops and then after few seconds all goes OK.
    No drivers at AK website. Any clue?
    Newest firmware.
  6. shimigg
    Is there a way to enable developer options on the SR15 ?
    I have a problem with bluetooth headphones where i need to up the volume to really high (110+) to hear something ,
    looking for the "Disable\Enable Absolute volume" on the device, is there a way to enable this ?
  7. mmu16
    So are your bluetooth headphones cranked up to max?
  8. shimigg
    For those with volume controls , yes, but those without volume controls are the problem.
  9. mmu16
    what model bluetooth headphones are you using?
  10. shimigg
    Sony WF-1000X
  11. mmu16
    Yeah those are noise cancelling ones. Pretty sure the noise cancelling algo impacts volume. It should have an option to switch off noise cancelling. try it that way and see
  12. gunwale
    Anyone experiencing battery draining too fast after last firmware upgrade?
  13. singleended5863
    Nope. My SR15 is fine. The battery is just drained like before nothing changed.
  14. bgtip
    As a matter of fact I have this uneasy feeling.
  15. gunwale
    Is your wifi on? My wifi used to be on all the time.
    Now switching off wifi fixes the issue.
