Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
112 113 114 115 116 117 118 119 120 121
123 124 125 126 127 128 129 130
  1. noobandroid
    im not very happy with the ui , but compensated for me is the sound, i aint going to fiio either, their frequency of new products totally triggers me
  2. emrelights1973
    @JasonNYC could you please help me?
  3. nekromantik
    What flaws?
  4. Onurb63
    Here same issues...after firmware update , ,external Dac not working..tried 3 different Dac (Mojo, ifi xdsd and Rme !!!
  5. Ninosan
    meanwhile I installed Foobar 2000. Finally an equalizer that works better and works also with BT.
    Well the player is not very confortable but at least it works.
  6. JasonNYC
    I have reported the issues to our dev team.
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  7. JasonNYC
    I have reported the issue to our dev team.
  8. JasonNYC
    How much free space is in internal memory?
  9. emrelights1973
    56gb it is empty
  10. JasonNYC
    Try a soft reset before attempting the update. While the player is turned on, press and hold the power button for 10 - 15 seconds until the player shuts down. Once the player shuts down, press the power button again to turn it on. Attempt the update once it restarts.
  11. Ninosan
    Too many problems, limited management and non-advanced BT (without LDAC).
    I was authorized to return it. Now I go to Fiio M11, it costs less and I think it is more suitable for me.
    Thank you all for your help.
  12. imexdanny
    I’ve explained this in several previous posts.
    So my main gripe is that the unit will not copy WAVs with metadata info. Half my music library is WAV, I could convert but I’m perfectly happy using VOX via iPhone with FiiO Q5 & Dragonfly Cobalt. VOX plays WAVs with artwork and correct data and this set-up sounds superior to the SR15 anyway.
    Battery life is poor. The unit loses battery charge even when it’s turned off and not touched for a day or two.
    The unit overheats like crazy, some will be fine with this but it is not a sign of a high-end product if you ask me.
    I see other flaws commented by other people also but the ones I have noted are enough for me to return.
    Ultimately I didn’t really need a DAP I was intrigued and liked the idea of no wires / amps etc to have to set up but ultimately for the money this product was a big let down for me.
    The functionality of these DAPs has a little way to go before I’ll invest again.
  13. Onurb63
    After Soft Reset , this problem disappears !
  14. emrelights1973
    I got it many tnx
  15. nekromantik
    no issues with connecting to PC here.
    usb storage mounts as normal.
    @JasonNYC Any updates on Neutron player?
