Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
99 100 101 102 103 104 105 106 107 108
110 111 112 113 114 115 116 117 118 119
  1. kenchar
    Mine does the same with the sideloaded Tidal app.
    The other day instead of skipping two songs it would go all the way to the end of my track list but a restart fixed that.
  2. VegasC
    and another issue is, i disabled the floating back button in settings but still shows in spotify
    @JasonNYC
  3. JasonNYC
    This issue has been reported already and has been passed along to our dev team.
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  4. JasonNYC
    Disabling the floating back button only works when playing back songs stored in internal or external memory. As a number of Android apps require the presence of a back button to function correctly, it cannot be disabled when using any streaming app installed via APK.
  5. VegasC
    Thx! Waiting for the fix
  6. JeremyLaurenson
    @JasonNYC what is the status of this - its been months now.
  7. gazzington
    Anybody know how this dap compares to hiby r6pro, dx220 and n6ii on a purely sound level? I have an sp1000 for home use but after a dap for work
  8. singleended5863
    SR15 has neutral sound with nice bass and not too smooth like DX220 and UI is fast. It is good for carrying around outdoor.
  9. MadDane
    Agreed.
  10. JasonNYC
    I was told they are still working on it. As the issue relates to the implementation of our Open App service, it was going to take some time to fix the playlists without breaking OpenApp, which is what happened when OpenApp was added, it broke playlists.
    I asked for another update. Sorry I don't have more info at the moment.
  11. marcus2704
    Would anyone be able to provide information that might help me choose between a SR15 and a Chord Mojo/Samsung S8 setup? I have Beyerdynamic T5P Gen 2 headphones, and use Tidal HIFI.
    Is the SR15 able to provide amplification beyond my Samsung S8 (which I have to max to drive the T5Ps to reasonable levels)? I was able to demo a Mojo and it had no problem going well beyond my personal volume limits.
    How well does the Tidal app work on the SR15? Can I save music for offline listening or is it streaming only? I would want to add an additional SD card to expand the storage, would this be available as a storage location within the Tidal app or would it only use the built in storage?
    An all-in-one device is very appealing particularly as I do a lot of commuting, and in this regard it makes more sense than the Mojo, but the Mojo probably (?) sounds better and could provide the levels of amplification I need. I hope to demo the SR15 soon, but would be grateful for anyone who could provide some feedback :)
  12. Ninosan
    Ciao,
    Sono nuovo nel forum che ho scoperto solo di recente.
    Ci scusiamo per il mio inglese, ma cerco di ottenere aiuto dal traduttore di google.
    Recentemente ho comprato un SR15 che è il primo lettore portatile per me.
    In seguito dico anche le mie impressioni, che per ora sono un misto di piacere e delusione.
    Nel frattempo, tuttavia, vorrei chiedere alla comunità qualcosa. Ho notato che l'equalizzatore non ha effetto con le connessioni Bluetooth. Lo confermi? È normale o un difetto?
  13. singleended5863
    Hello,
    I'm new to the forum that I discovered only recently.
    We apologize for my English, but I try to get help from the google translator.
    I recently bought a SR15 which is the first portable player for me.
    Later I also say my impressions, which for now are a mixture of pleasure and disappointment.
    In the meantime, however, I would like to ask the community for something. I noticed that the equalizer has no effect with Bluetooth connections. Do you confirm it? Is it normal or a defect?
    Wildcatsare1 likes this.
  14. marcus2704
    I am considering an SR15 but one thing that puts me off is the price of the case (which I believe should be included with the unit), the minimum I have found so far would set me back £50!
  15. dawsonsweek
    Yeah, it's ridiculous. Especially when the case isn't even leather!
    I bought this for £10. The SR15 fits perfectly, but the downside is you need to pull it out to change tracks.
    https://www.amazon.co.uk/gp/product/B01M0EFSFL/
