Astell & Kern SR15: A&norma Impressions & Reviews
Discussion in 'Portable Source Gear' started by pitch_black, Jul 29, 2018.
98 99 100 101 102 103 104 105 106 107
109 110 111 112 113 114 115 116 117 118
  1. MadDane
    JasonNYC,
    Lyrics are in ID3tag tapping album art just brings up a list of...
    Genre
    Year
    File Size .etc
    Can't seem to find a "Lyrics" setting anywhere.
    Thanks,
    Claus
  2. punknotyet
    @MadDane , there is a button "LYRICS" in upper-right corner of the screen after tapping of the album art.
    It's not visible, if lyrics are absent in the currently played file.
  3. Recordedmusikaddict
    Thank you
  4. MadDane
    Thanks,
    I'll try it when I get home tonight.
    Claus
  5. MadDane
    Alright still doesn't work. My lyrics were added using mp3tag editor, as "UNSYNCEDLYRICS" anyone know if this might be the issue?
    I'm really into having the lyrics, it's a big part of the musical experience for me.
    I appreciate all your help so far.
    Claus
  6. JasonNYC
    I had some issues with lyrics last night when I tested. Looking into what the issue may be today. I will update you when I have more info.
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  7. punknotyet
    @MadDane , I use freeware utility TagScanner (https://www.xdlab.ru/en/download.htm) to deal with tags.
    It allows to insert lyrics, that are seen in Norma.
    Maybe it works somehow differently than mp3tag editor.
    Also, do you insert lyrics to the file, that is already located in DAP's memory, or to the file, located on your computer, and then copy it to DAP?
    I used the 2nd method.
    Not sure if that's important, but who knows :).
  8. MadDane
    Thanks Jason I was starting to scratch my head a bit!
  9. MadDane
    I've been told by a few folks that mp3tag/foobar/tagscanner, etc. All "Should" work.
    I tried both ways.... unit connected via usb, and then memory card in laptop.
    Thanks for your response, I appreciate the help.
  10. Dav72D
    Does anyone know if there is any way to improve the responsiveness of the screen?
  11. MadDane
    JasonNYC
    Any word on the missing lyrics?
    Thanks,
    Claus
  12. JasonNYC
    Sorry, not yet. I sent a message over to our software team to ask a question about it and didn't get a response back yet. I will follow up with them when they get into the office in a few hours.
  13. MadDane
    Thank You
  14. Shivas
    Would it be advisable to get an SR15 now? Are there any other opinions on the soundstage and resolution in comparison to Hiby r6 pro, sony WM1a or se100? would it be more musical or analytical?
  15. VegasC
    hardware key issue with spotify using sr15(1.14),when screen is off, if i want to skip to the next song in spotify, i press the "Next" button, it will skip two songs sometime. But when screen is on, everything is fine.
    @JasonNYC
