Hi @schleppsound
My question for you or anyone else viewing my post is whether or not $700 is overkill for a DAP if I’m only listening with the Quad Driver or maybe even the M11 is overkill?
I don’t think either would be, but I’m new to all of this and would appreciate the insight of more experienced audiophiles
my dear friend, your question has a very simple answer, the better the headset or ear in will be and the better the result you will feel.
Now I have taken some Meze Rai Penta and I use them with sr15 and I can assure you that this tiny setup has absolute level performances and you can look at the toys in my profile to get an idea of the things I listen to.
In addition to headphones, it is essential that you use high quality files, for example using Qobuz Sublime which I installed in the sr15 and with files hires the end result is even better.
