Astell & Kern SE100: A&futura Impressions - Reviews
Sep 16, 2018 at 10:13 PM Post #453 of 1,512
PinkyPowers
Reviewer: The Headphone List
Kansas City, MO
Sep 17, 2018 at 6:40 AM Post #454 of 1,512
Cherubian
Czech Republic
Sep 17, 2018 at 8:32 AM Post #455 of 1,512
SebDuke
Hi,
Thanks for your review... you've got a problem with you model ?
For a luxury brand, luxury quality is required :p
(on left corner, back glass is not really aligned )
Sep 17, 2018 at 9:45 AM Post #458 of 1,512
javahut
Nice review, how is this dap in the bass department thx
As long as you have phones or IEMs that have extension into the low end, the se100 will provide it. It has great extension into the sub-low end. However, se100 won't add any low end to help with phones or IEMs that are shy of it.
I'm a bit of a basshead, and it has plenty for me thru Westone W80s.
Sep 17, 2018 at 10:07 AM Post #459 of 1,512
PinkyPowers
Kansas City, MO
Sep 18, 2018 at 11:07 AM Post #462 of 1,512
Tinnitus Man
United Kingdom
Wondering if anyone can assist me. I cannot seem to connect my SE100 to my Windows 10 laptop as the USB on MTP does not seem to work. Any ideas? Thanks in advance.
I'm not sure why that wouldn't work. I have my SE100 connected to my Surface 4 Pro without any problems in MTP mode.
Sep 20, 2018 at 2:03 PM Post #463 of 1,512
umbrellaus
Albany
I find the T8IE MKII's have too much bass if they are pushed to far into my ears. I found this to occur with my SE100 and my AK70. I switched to spinfit tips (purchased separately) that work better for me than the tips that came installed originally on the T8IE MKII's. I have not tried the T8IE MKII's with the Comply foam tips that also came in the box. I do all my listening with the 2.5mm balanced output and find it better than the unbalanced output.
Also, thanks for all the internal hardware info on the SE100.
I think the reason is that the t8ie mkii's sound signature, which is tuned for more bass compare to Xelento.
Sep 21, 2018 at 2:16 AM Post #464 of 1,512
androidjedi
London
strange thing happened to my se 100.. process sysytem not responding message..reboot problem temporarily disappears however music from sd card cannot be read..get unplayable format for all which is bemusing as it was working properly until this happened. anyone care to let me know what to do? will try and wipe cache etc and factory reset and see what happens.
