Astell&Kern SA700 - Past meets Present
- Thread starter Levanter
lonelyboy888
Does anybody here know how to import m3u file (or another format of playlist) from computer to the sa700 ?
I want to know too. I am using SP1000M but the m3u file created in computer cannot be read by my SP1000M.
USB Audio out to the Mojo.@JasonNYC Can you comment?
https://us.astellnkern.com/apps/help-center#!hc-which-players-support-usb-digital-audio-output-1
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
Hello, I am a Hong Kong user, I just bought sa700. After I update 1.21cn, USB dac connects to hugo2 and it will make a noise when the screen is turned off. It is also the case to go to the store and change the new machine This situation)
Finally found a way to do it thanksDoes anybody here know how to import m3u file (or another format of playlist) from computer to the sa700 ?
Dietmar Görtz
Hi,
Maybe someone is interested?
I sell a nearly new SA700 including original A&K leather case. Both in black.
Mai, 2020!
990,- Euros complete.
Shipping within Europe.
Best
Mai, 2020!
Best
lonelyboy888
Can you please share with me your method? Many thanks.
okay i'll post a little tutorial here to explain my methodCan you please share with me your method? Many thanks.
lonelyboy888
Thanks a lot!
Before the beginning we have to check some prerequisite:
So if everything is okay we can start:
- You need a Windows computer
- You need a SDcard in your AK DAP
- Make sure that your playlist is in ".m3u" format and the files encoding are in "Unicode (UTF-8)"
why we need to use this encoding method, because I noticed that if i use another one, some audio files with special characters can not be found by the player. - Make sure that the path of your audio files in your ".m3u" files are the same on your DAP or the SDcard for exemple:
on my SDcard i have a song named "HEAD-FI.FLAC" this file is in a folder named "HEAD-FI" witch is in "ROCK" folder
so the path in my ".m3u" file will be: \ROCK\HEAD-FI\HEAD-FI.FLAC
as you can see you don't need to add the ROOT name
- Go on your computer and export your playlists from your audio software in ".m3u" files and encoding in "Unicode (UTF-8)"
- Now connect your AK on your computer using the usb-c cable, you'll see a new device
(Exemple from my computer)
- Get in your SA700 device you'll see 2 Storage location (SD location and internal location)
- Open both of them in two different windows
- On you SD location you can stay on the ROOT for you internal location (your AK device) go to the "Playlists folder"
- Drag and Drop your exported playlists in ".m3u" files and encoding in "Unicode (UTF-8)" on your SD location
Watch out if your playlist is composed of more than 4000 songs Windows will block the transfer - when you do that the icon of you playlist change for something like that
Watch out make sur that the file size is not at "0 ko" if it is try to rename your playlist, be sure that you are in ".m3u" or downsize your playlist - Now you can Drag and Drop the playlist from your SD location to your internal location in the "Playlists folder"
- After the transfer you can disconnect your AK device, go to playlists and ENJOY
lonelyboy888
why we need to use this encoding method, because I noticed that if i use another one, some audio files with special characters can not be found by the player.- Make sure that the path of your audio files in your ".m3u" files are the same on your DAP or the SDcard for exemple:
Watch out if your playlist is composed of more than 4000 songs Windows will block the transfer- when you do that the icon of you playlist change for something like that
Watch out make sur that the file size is not at "0 ko" if it is try to rename your playlist, be sure that you are in ".m3u" or downsize your playlist- Now you can Drag and Drop the playlist from your SD location to your internal location in the "Playlists folder"
Thanks, let me try in my SP1000M.
OkayThanks, let me try in my SP1000M.
keep me informed if it work for you
Alright I’ve been scouring the web and it’s literally ridiculous how little that is written on this player. Can those who own it alongside any other source gear / players do some side by side comparisons? Ones I’d be most interested in are comparisons against: Mojo
Dx220
Sr25
Cayin n6ii
Kann cube
Sp1000m
FIIO m11 pro
FIIO m15
Dx220
Sr25
Cayin n6ii
Kann cube
Sp1000m
FIIO m11 pro
FIIO m15
Gift
Hi there.
Long time lurking on this forum and here is my first post.
Seems to me there is not much interest on this player. And probably less since RS-25 released.
Anyway I'm really enjoying it for some months now and could not be happier. Usually coupled with a Kaisser Encore, Django and my beloved Etymotic ER4XR.
A very good user interface (I come from Sony ZX2) and lot of resources that all work flawless since first day. From my own collection of HD music on the SD to Tidal and NAS easily acces. Being the best part of all sound quality.
I encourage all members with this player make Alive this thread with your experience with It.
Best Regards.
Best Regards.
Tommy34
Glad to hear you're enjoying it. I plan on upgrading my DAP soon and am torn between this one and the Lotoo Paw 6000. I'm sure I'd be happy with either one, but we'll see.Hi there.
Best Regards.
