Astell&Kern new flagship A&Ultima SP2000
Jun 10, 2020 at 7:32 AM Post #3,361 of 5,429
jupiterianvibe
Atyrau, Kazakhstan
I mass copied my music into internal memory and from time to time I am arranging album artwork in the folders by deleting the existing art and copying a new one. Sometimes the new artwork appears after the restart and rescanning of the library but sometimes SP2000 just continues to show the old artwork even though it is no longer in the directory. There is no files in the AlbumArt folder on the internal memory, as well. How do I make SP2000 to show the correct artwork? Completely delete the folder and re-paste it to the memory?
Jun 10, 2020 at 8:41 AM Post #3,362 of 5,429
Progisus
Canada
It’s probably lookung at the art embedded in the file. You may need to change that.
Jun 10, 2020 at 10:36 AM Post #3,364 of 5,429
Irvine, CA
I would recommend doing a manual media scan to reindex everything when you swap out album art. Settings -> System Reset -> Initialize media scan. If you have playlists on the player, make sure clear playlists is not checked. A manual scan can take up to 10 minutes depending on how many files are in internal and external memory.
Astell&Kern Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support@theinvixion.com
Jun 10, 2020 at 1:54 PM Post #3,365 of 5,429
Steeve
Northampton, United Kingdom
I would wait for the next version of the Qobuz app as we already know there were some issues with the current version. It was supposed to be released as early as the end of last week, so I suspect it should be available any day now.
@JasonNYC I shall but with respect there are ‘some issues’ with every release of Qobuz on A&K players. I have still to find out whether it can cope with more than 300 downloaded albums without falling over in a heap. Seems little point in even testing it at the moment.
Jun 10, 2020 at 1:56 PM Post #3,366 of 5,429
Steeve
Yes, that's what I'm doing indeed. However, I have not yet seen a qobuz app on my AK devices that worked flawlessly, so I'm not counting on the new release to solve all issues...:smile_phones:. Who knows, maybe we'll be pleasantly surprised. I'm glad I have tidal as a backup..
I fear not in my lifetime and I don’t believe in streaming after death!
Jun 12, 2020 at 4:13 AM Post #3,368 of 5,429
Steeve
@JasonNYC Response from Qobuz to my bug report which looks like a non-starter. I’ve intimated this isn’t possible but, for good protocol, said I would check with A&K.
Jun 12, 2020 at 6:50 AM Post #3,369 of 5,429
denis1976
Portugal
What a great album to listen with the sp2000, great sound stage that involves you, a organic delicious tonality, this Dap is awesome simply awesome IMG_20200612_114806.jpg
Jun 16, 2020 at 12:10 AM Post #3,371 of 5,429
jupiterianvibe
Atyrau, Kazakhstan
My AK240 was listing the albums under related artist in chronological order in the UI if the music file tag has the album release date. SP2000 does not do that. As far as I can understand, SP2000 UI lists albums as per their loading time to internal memory. Is there a way to fix this?
I saw that SR25's latest firmware update brings back the chronological order option. Any idea if it is coming to SP2000, as well?
Jun 16, 2020 at 4:52 AM Post #3,372 of 5,429
Steeve
Nul points so far to Qobuz support
Sent: 16 June 2020 09:43
To: support-help@qobuz.com
Subject: Re: Qobuz | Your request number 00129583 [ ref:_00D58JmCx._5001tUgCbv:ref ]
Hi
As mentioned previously, Astell & Kern devices do not have access to Google Playstore.
There doesn't appear to be an attachment to your previous message.
Regards
From: noreply@salesforce.com <noreply@salesforce.com> on behalf of support-help@qobuz.com <support-help@qobuz.com>
Sent: 16 June 2020 07:49
To:
Subject:
Dear customer,
Thank you for your message.
You can load the app through the Google Playstore if the device has access to it, otherwise you should be able to upload the manual version I have attached in this message.
Best regards
Jun 16, 2020 at 8:51 AM Post #3,373 of 5,429
subguy812
Reviewer: Audio Rabbit Hole
Florida
While I receive the app will not function properly because of lack of Google Playstore access, it still appears to function. Am I missing something? I am on 5.9.0 Qobuz. I have not heard stuttering or hitching. I am not saying it is perfect, but it faster than on my Cube.
Jun 16, 2020 at 9:15 AM Post #3,374 of 5,429
MatW
EU
Be glad! The previous version was ok for me, but not for others. The latest release is not usable for me, only using tidal until the next qobuz release. I don't know why it apparently works on some devices and not on others. Factors that might have something to do with it include having offline content or not and whether it's a fresh install or upgrade from a previous version. In any case, I'll wait for the next release, and if that's not better I'll go back to 5.8.0.1
