Astell & Kern KANN - DAP with Massive Storage & Battery
Discussion in 'Portable Source Gear' started by Levanter, Apr 4, 2017.
72 73 74 75 76 77 78 79 80 81
83 84 85 86 87 88 89 90 91 92
  1. SirGin
    Yes Windows 10 using jRiver's Media Center works great for synchronizing with KANN. Unfortunately, that is not the case with Mac.
    On the other topic, disappointed with KANN that the Play/Stop button does not work with screen off. Great player otherwise.
  2. Silvertouran
    You need to unlock this feature. Swipe down from the top then press the padlock symbol. This allows the play/stop and volume to work with the screen off.
    SirGin likes this.
  3. Miniculthero
    I have the kaiser noble encores on their way... can I ask what cable you use to run it in balanced mode- thanks
  4. kertong
    I got the cables in Japan - Nobunaga Labs "Medusa" 2.5mm TRRS - looks like this: https://www.amazon.com/NOBUNAGA-Labs-MEDUSA-NLP-MED-balance/dp/B011TBN28A
    I'm not sure I would recommend the cable, though. The right side pins were *very* difficult to insert into the Kaisers, and once I pulled them out to put the stock cable back in, the stock cable went in and pulled back out with very little resistance - I think the NL cables stretched out / loosened the socket quite a bit! :frowning2:
  5. Shetzu
    Glad your issue is resolved. Happy listening.
    kertong likes this.
  6. Miniculthero
    Does anyone know of a really good 3.5mm to 2.5mm adapter plug to run balanced mode on Kann. I have Kaiser nobles and frightened of stretching the sockets with aftermarket cables- many thanks
  7. Miniculthero
    That’s a real shame, I hope they still work ok. I’ve heard similar stories about people experiencing same issues. Wonder if they’d are any decent 2.5mm adapters for balanced mode
    kertong likes this.
  8. Shetzu
    kertong likes this.
  9. Shetzu
    I got one on Ebay.com for 65$ which works perfect.
  10. Miniculthero
    Eureka, thank you so much for this, I’ve ordered one.. copper and silver too in the same format as the noble stock cable, so in theory should be a flawless union. Cheap as chips. Cannot wait to see what the Kann can do with these bad boys. Taking outside audio to the next level
  11. Shetzu
    Goodluck with your new purchase. I am sure it will work
  12. JasonNYC
    Hope everyone that celebrates had a good Thanksgiving. Wanted to remind US/Canadian customers about our Black Friday/Cyber Monday specials:
    15% of SP1000, KANN and AK70 MK II on Black Friday (11/24) from 6 am - 10 am PST and Cyber Monday (11/27) from 6am-10am & 5pm-8pm PST. Get an additional discount on top of the 15% off if you subscribe to our email newsletter (details in the newsletter). https://us.astellnkern.com/collections/bfcm
    Special Bundle deals available from Wednesday, 11/22 - Monday, 11/27. Some examples of bundle deals:
    AK70 MK II + Case - $699
    AK70 MK II + Michelle IEM - $999
    KANN + AK CD-Ripper MK II - $1,099
    SP1000 + Standard or Cordovan Leather Case - $3,499
    SP1000 + AK CD-Ripper MK II - $3,499
    Check out the Astell&Kern US E-Store for more information and to sign up for the newsletter - https://us.astellnkern.com
    Astell&Kern Stay updated on Astell&Kern at their sponsor page on Head-Fi.
    https://www.facebook.com/astellnkern/ https://twitter.com/astell_kern https://instagram.com/astellnkern https://us.astellnkern.com support.inc@iriver.com
  13. Shetzu
    Thanks Jason for your wishes.
  14. Miniculthero
    Some of the micro sd cards are in the Black Friday deals. What is maximum capacity for Kann.. and which cards have the best success/speed with Kann. Are Sandisk any good?
  15. Shetzu
    Maximum capacity card is 400Gb and well tested by A&K. All cards have good success speed. However, the bigger your library the slower the scan of your files would be.
    Shmuel likes this.
