macdonjh
- Sep 16, 2015
Had this issue with my AK100ii, just factory reset it and then do a library scan.
I will try that. Thanks for the idea.
I tried the SETTINGS -> RESET ALL SETTINGS, then LIBRARY SCAN. It still wouldn't play most of the FLAC files on my unit.
I couldn't find, even on the Astell & Kern website, any other reset options.
Then I tried reformatting and reloading some songs, FLAC files. Still no luck.
I'd like to buy an AK 70II, but not if it won't play FLAC files reliably.
I have several hundred of Flac and I never encountered any problem with them.
This is a new problem for me. I've been happily using my AK Jrs for a bit over a year. This problem with FLAC files is about a month old. No solution in sight.
Weird, are these files on a sd card? if that the case could be that there is something wrong with the card?
Did you try the same files on a different player?
At this time the only players I have are a pair of AK Jrs. I don't use the SD card slot since I only load up a couple of hundred songs at a time and then use it as a juke box. The problem has to be with the internal memory, or my server software not converting the files from WAV to FLAC properly suddenly.
Been using the AK70 for the past year. No real problems until the last couple days. It wont turn on. Charged it, but now it is dead. .... Will need to try to return it. In the end, most likely will not purchase a A&K again.
People who own old PS3 can rip them as .iso images, when certain conditions met, not really legal from sony's point of view.Rookie question: if SACD/ DSD can't be ripped, why does it matter if a DAP has DSD capability? Where are digital DSD files coming from? In order not to hijack this thread, please PM with your comment or a link to the answer. I've searched here for "ripping DSD" and "ripping SACD".
