Astell&Kern AK380
post-13342190
Post #8,176 of 8,903
raypin
San Fransokyo
San Fransokyo
Nice - coz I pre-ordered one without hearing it after reading about the tech and a couple of initial reviews. How would you rate it against the Shure stats (which I was not impressed with) and the Layla, or K10? Just tuning difference, or a step above them?
Mm...initial impression: the KSE 1500 sounds thin compared with the Fourte.The Shure key strenght is clarity and speed but the bass (lack of) can be problematic (depending on the genre). I don't have the K10. Against the Layla (I have the Layla 1), I need to do a side-by-side comparison but the tuning, if I had to guess, is somewhat similar. Also, if I had to guess, the bass quantity would be the same at the 12 or 1 o'clock position of the bass adjuster of the Layla 1.
post-13342707
Post #8,178 of 8,903
Dellwolf
Lincolnton, North Carolina
I actually like U18 more than TiaForte with ak380cu+amp cu.
I'm not really a fan of either the U18 or the TiaFourte, I don't feel the prices are justified, especially with the Fourte.
post-13343796
Post #8,179 of 8,903
LouisArmstrong
It is all subejctive I guess, can we justify the price of the 380 for example?
post-13343909
Post #8,180 of 8,903
Gosod
Europe!
Europe!
I listened to our АК380 with Hd600 headphones, was the sound that I liked (actually I love her big headphones) but buy the Hd600 for home use.
post-13343914
Post #8,181 of 8,903
JeremyLaurenson
Website
www.map-pin.com
Any Mac users here also totally frustrated with Android File Transfer and AK's software? Im returning my player today and I hope they'll fix this some time, after which I may switch back.
I can transfer between 6 and 18 tracks before it hangs and dies, requiring disconnect/reconnect or even a reboot. At more than 6k tracks, I couldn't take it anymore.
I have gone so far as to build my own software, and lo and behold its an issue with AK and not MTP and Macs.
If you're a Mac user, please take a look at this thread where Im trying to drum up support for getting them to fix their stack.
Please, no PC vs Mac trolling or "Discussion"
post-13344008
Post #8,182 of 8,903
Dellwolf
I don't own an AK380, but if I had the cash to buy one, I would. However, I would not for the TiaFourte, I believe the similarly priced Empire Ears X Effect Audio - "Arthur" is much, much better. My review of the Arthur will be posted soon.
Reactions: ironpeg
post-13344028
Post #8,183 of 8,903
Gosod
Europe!
Europe!
if you have the opportunity, listen to it first before paying.
post-13344067
Post #8,184 of 8,903
bflat
San Francisco
San Francisco
Never had it this bad with my AK240, but frequent disconnects. On the AK380, no issues at all on my Mac. I copied a full 500 GB of files in 2 clicks - one for internal and one for SD card. Also, it's only a pain on the initial copying as ongoing copying of albums as I purchase them pose no challenges at all. From that standpoint, I personally would not want to pay for a more elaborate utility.
post-13344111
Post #8,185 of 8,903
Dellwolf
[COLOR=111111]if you have the opportunity, listen to it first before paying.[/COLOR]
I've had the opportunity to listen to every product that I have talked about. I wouldn't say something if I hadn't.
post-13344143
Post #8,186 of 8,903
JeremyLaurenson
Website
www.map-pin.com
I just want them to fix the OS. Had problems on AK100II, AK300 as wel
post-13344179
Post #8,187 of 8,903
bflat
San Francisco
San Francisco
It's not a "fix". Mac OS does not support MTP and will likely never support MTP. It's up to app developers to come up with a better solution. You would have much better luck convincing AK to come up with one.
post-13344195
Post #8,188 of 8,903
JeremyLaurenson
Website
www.map-pin.com
It's absolutely a fix thats required.
I am NOT saying they need to trash MTP and do something else.
I am more than willing to use Android File Transfer but their old MTP stack in their customized Android OS has old bugs that badly affect these tools.
3rd party tools that they link to and recommend on Macs all have issues (copies around 12 songs before crashing) whereas using those exact same tools on an Onkyo DP-X1, also running android, has zero issues with thousands of songs.
I want them to fix their MTP implementation.
Its absolutely an issue with the AK implementation of MTP under their highly customized OS.
post-13344227
Post #8,189 of 8,903
bflat
San Francisco
San Francisco
I think we are saying the same thing. I just want to make it clear who we should yell at. Mac OS has no MTP stack so nothing to "fix" with Mac OS. The "fix" will have to come from:
Apple - why no MTP support like Windows?
AFT - Google owns this, but in my own experience both AK380 and Sony Xperia Z5 phone work flawlessly so doubt fix is here. Good that you mentioned Onkyo because I had one briefly and can't remember having any issues either. However, it has not been updated since 2012 so who's to say there's no issues here?
AK - custom os and/or hardware implementation. I personally would agree this is where the likely issue stands. I've tried 3rd party MTP apps with the AK240 and did not have a good experience either.
Take your pick
post-13344260
Post #8,190 of 8,903
JeremyLaurenson
Website
www.map-pin.com
Take your pick
Vendors that are using android as their operating system will have to use MTP, otherwise they have to create their own solutions and will have fragmentation.
The answer is for them to fix the MTP code, and the fixes are clearly already in the Google Android code base.
There is an alternate version of android file transfer that's actively in development that I am helping build and provide for OSX which is way better but still stumbles on AK devices. Its the basis for the tests I link to and want to provide to AK. Its totally open (GPLv3 license) and current.
Http://Jeremy.laurenson.com/AFTOSX
