Astell&Kern A&ultima SP3000T
Nov 26, 2024 at 11:47 AM Post #451 of 616
My is brand new, last for around 9-10h with tubes, local playback. Which feels great after Lp6ti which barely can push out 6h
Nov 27, 2024 at 2:07 AM Post #455 of 616
I guess I could deactivate WiFi and lower tubes current, but battery life is not really critical. Also, usually I don't use DAR, the battery probably lasts longer without it. But for a long flight, for example, could potentially be annoying (who am I kidding, there's always a battery in my backpack).
Nov 27, 2024 at 2:19 AM Post #456 of 616
I would bet DAR sucks up most of it.
Nov 27, 2024 at 4:54 AM Post #458 of 616
hm tested overnight - approx 8h flac playback from sd card, tubes high current, 60 volume, no wlan, but with dar
Nov 27, 2024 at 12:39 PM Post #459 of 616
That is actually my main criticism, the battery consumption and probably its capacity. A more powerful unit and improved energy management would certainly have been desirable here. Especially considering that this AK has tubes that tend to consume more energy than conventional pure transistor devices.
If you really wanted to achieve the AK factory specifications, which I fundamentally doubt, then you would probably have to make extreme adjustments to the device's performance, which would probably have a negative impact on its excellent sound properties.
Nov 29, 2024 at 4:44 AM Post #461 of 616
I wonder why the results are so different. I don't seem to be able to get under 20%/hour. Even with DAR off, low current, no wifi.
Any suggestions?
From my experience with daps its important to go through the whole 100% of the battery to estimate the time it lasts, first 20-30% are drained within 1.5-2h usually then it slows down.. at least for me with sp3kt
Nov 29, 2024 at 8:25 PM Post #462 of 616
Hello @JasonNYC ,
Do you know if there is a more recent version of Roon ARC that can be uploaded to the servers? the latest I have (1.0.59) stopped working.
Thanks in advance for any help and/or suggestion.
Dec 1, 2024 at 1:55 AM Post #463 of 616
(deleted)
Dec 1, 2024 at 7:56 AM Post #464 of 616
Hello @JasonNYC ,
Hopefully you realized by now you need to update your Roon Server and not ARC.
