The EQ preset for NOVUS is what our (AK's) sound engineers feel brings out the best in the NOVUS when paired with the SP3000T. Since sound is different for everyone and highly depends on the music you are listening to, what mode you are in, etc., I always recommend playing around with the different settings, try with the EQ setting enabled and with it disabled. Personally, I think you will find some stuff sounds better with the EQ setting and others you may like better without.With the Astell&Kern x Empire Ears Novus IEMs being in route to some authorized online dealers and therefore should ship out this week to customers who pre-ordered the Novus. On the Astell&Kern Ultima SP3000T do you recommend using the preset Novus EQ setting when listening with the Novus on the SP3000T? I was planning on using Hybrid mode with high current, but wasn't sure whether to use the Novus EQ or not. Also should DAR be used on hi-res lossless music or is it mainly for compressed lossy music?
Thank you.
For DAR, I think it is pretty evenly split among owners of AK devices with the DAR option on whether they use it or not and if they do PCM upconversion or PCM to DSD conversion. Again, I it really all depends on your musical preference and your sound preferences. I highly recommend again trying all the options to find out what sounds best for you. I'm sorry, I know that is not too helpful, but again, personal preference has a lot to do with it. There is no right or wrong answer.
Stay updated on Astell&Kern at their sponsor profile on Head-Fi.
