Total bummer about the included Tidal's lack of offline downloads. Leaves me to wonder, when you sideload Tidal in order to allow offline downloads, are there then two versions of Tidal on there? It's a shame you can't update these apps through the device... I hope there's a good reason for it....
The cards seems to be plastic (casing of it) but the top part that sticks out is metal and matches SE180 chassis. The fit is a little springy and there is a very small gap, but it does fit like a glove.
If you were to download offline files on both sideloaded Qobuz and Tidal, would they be compiled together in the SE180's local files? I assume not, but if it was to get a ROON update, what would that then look like?
Hmmm. First Portable Player With Interchangeable All-In-One Sound Modules? In A&K products line?
Thinking fairly, the first dap which has changeable DAC+AMP+Output unit would be Cayin N6ii.
Is there something new in SE180?
I did offline download with Amazon Music HD, files are saved locally on internal storage, and just like on your smartphone can only be accessed from within corresponding app. I don't have any purchased music, that one is probably saved and available to be played by A&K audio player. But I would imagine that offline download content is encrypted and can only be played by that specific app when you logged in.
Yes, this one is the first for A&K product line As I mentioned in my SE180 review, A&K didn't reinvent the wheel here, just perfected it. In their design you have two side release buttons for easier exchange of modules without a need for screwdriver. Plus, a big step up for A&K to have both 3.5mm SE and 2.5mm/4.4mm BAL on each module, configurable as either PO or LO, and to include LDAC BT codec, plus to have Normal and High gain, and access to Digital DAC Filters on each module. Again, this is all a BIG step forward relative to A&K product line.
Makes perfect sense! Was just hoping to avoid bouncing back and forth between Tidal and Qobuz offline downloads without purchasing music. Can ROON be sideloaded or does it have to be "ROON capable"?
The Roon Remote app for Android cannot be sideloaded on any AK player. Roon Ready support will be expanded to additional devices, but currently do not have information on when/if Roon support will be added to the SE180 or other players in the AK line.
Thanks so much for that! I understand the SE180's file management well now. A separate thing I'm wondering is...
Do all of your offline downloads have to be re-downloaded when you have to manually update the sideloaded version of both Tidal or Qobuz? That would be pretty rough if I have a large offline library.
Also, I know you have demoed your fair share of DAPs and that it also depends on amps and circuitry, but do you have any general description on the difference between AK4497 and 4499 dac chips?
