Dec 20, 2013 at 9:00 PM Thread Starter Post #1 of 2
hydrans5
I just received a brand new Asgard 2, Modi and Adam Audio F5s. For some strange reason, the left channel speaker cuts out intermittently.... Is this normal for burn in or a common issue? Does anyone know whats going on here?
Dec 20, 2013 at 9:53 PM Post #2 of 2
Try changing cables, maybe there's a faulty cable. Try switching L for R and see if it's the other channel that cut off. If so, it's the cable :) If not, contact Schiit, burn-in process should not affect the level and even less the signal sent to either channel. Hopefully, it's only a cable and it's an easy fix !
