Are noise-cancelling headphones making us deaf?
Nov 18, 2006 at 1:32 AM Thread Starter Post #1 of 9
jdimitri
This just randomly popped into my head today
Noise cancelling=making 'antinoise' to cancel the outside noise. What if the noise outside is very very loud (eg planes)?
To cancel the noise wouldn't the noise cancelling thing have to do whatever they do at the same or higher level?
Or is one of those 'if you can't hear it it can't hurt you kind of thing'
Sorry if it's a stupid question
Btw.. http://en.wikipedia.org/wiki/Noise_c...ing_headphones has IEMs listed as noise cancelling.. what the
Nov 18, 2006 at 1:52 AM Post #2 of 9
I'm pretty sure the engineers thought of that right away - it was the first thing that came into my head when I read about active noise cancelling. The anti-noise circuitry probably has a maximum, beyond which it will either quit entirely or stop amplifying the anti-noise. It's one of the things that prevents me from getting this type of can, though. I'm not a big fan of adding noise of any kind to the signal chain - I don't like the hiss that it adds either.
Nov 18, 2006 at 2:02 AM Post #3 of 9
From my understanding, all the "anti-noise" is done inside the circuit and doesn't get passed to the ears to cause damage. Otherwise, to noise-cancellation technology would render us deaf. Besides, noise-cancellation headphones don't work nearly as well as IEMs. Just get a pair of decent IEMs for isolation and problem solved. No need for bulky headphones which require batteries to operate effectively.
Nov 18, 2006 at 2:13 AM Post #5 of 9
Originally Posted by nikongod /img/forum/go_quote.gif
the "anti noise" actually combines with the real noise, and they "neutralize" each other.
basic wave superposition that I learned from Physics A level...
Hence, the amplitude is 0 and you don't hear anything. However, they don't always get it right, so sometimes you do hear a faint hiss.
That's probably an extremely watered-down explanation of what actually happens.
Nov 18, 2006 at 2:56 AM Post #6 of 9
Ah that made everything clearer..
I thought the music AND antinoise would be coming out of the drivers into your ears and you know, making a noise orgy
..but appearantly not
Nov 18, 2006 at 3:05 AM Post #7 of 9
Even if it were the case, as long as the "anti-noise" is in the correct phase you should get amplitude reduction.
-Angler
Nov 18, 2006 at 3:36 AM Post #8 of 9
That is correct, it doesn't matter where the antinoise is combined, the total effect is that the level of sound *at your eardrum* is overall lower.
The anti-noise is usually only effective up to about 15dB total noise reduction under 1000Hz, which isn't a heck of a lot. Most IEM's can do better than that.
Nov 18, 2006 at 4:53 AM Post #9 of 9
Furthermore, if you're wondering where the original sound wave energy went, the physics of wave generation dictates that whatever produced the anti-wave must also absorb the energy of the wave it cancels. IE, the outside noise is "absorbed" by the speaker drivers, in terms of energy accounting.
