Snaques
- Aug 18, 2006
I travel quite a bit with airplanes, but the trips are pretty short, 1-2h. This means that some 70% of the time the plane is either ascending or descending. I would like to have IEM's there to block the noise, but got worried because of the pressure.
IEM's make a seal in to your ear. Now if you put them on while on the ground and take 'em off some 5km's higher is there a potential catastrophy for my ears. Because if the seal is good, the ears can't depressurize (that a real word?!?) and the pressure differences could really harm your ears when changed instantly.
So how are you using your IEM's during flights.
