noplsestar
Someone seems to like holding my silver arctic cable while sleeping
I absolutely concur with your comments which also apply to the Arctic Palladium Series. I have been using a two-metre palladium-plated silver cable from AC with Audeze LCD-X, Audeze LCD-4z, and Meze Empyrean (spreading the cost over 3 headphones since they all take mini-XLRs). The AC PS is breath-taking in its absence of sound quality, to my ears. The immediacy and transparency of the music are as though the headphones are directly connected to the headphone amplifier output stages. Like you, thankfully, my quest / experimentation is over. Now to save up for another set for Rosson Audio RAD-0...i've had an silver Arctic Cable for quite some time now, so am comfortable with writing this post.
It is most definitely my favourite cable with the Utopia. i enjoy it the AC cable with the Utopia more than the Danacable Lazuli Reference and Moon Audio Black Dragon (both terminated for Utopia). i've also used ultrashort adaptors with cables from Norne (Silvergarde S3), JPS Labs (Superconductor) and PlusSound (X8 gold plated silver). The Utopia is such a fast and resolving headphone, but so far i found only the AC plays to that strength. I felt the other cables listed above (aside from the Black Dragon) seemed to dull out the upper registry, rounding off the top end just a bit too much.
There is this amazing clarity and transparency with the AC cable. the leading edge to notes is so clean, making vocals so crisp and clear. i also thought it was the most holographic with amazing 3d placement of elements in the music. it also had by far the best soundstage width, both laterally and in depth. Even with busy passages and songs with lots of instruments playing, there is really really good separation and just crazy pinpoint placing. In the lower registry, low end extension and texture were great, and there was fantastic punchiness and impact. The utopia is definitely not lacking in bass!
i've done countless quick a/b comparisons with this cable and my other cables and it really is no contest. not to say that the other cables are not good, just that they sounded better with other headphones. for eg, i preferred the JPS Superconductor with the Abyss 1266 (naturally) and the PlusSound X8 with the Verite Closed. The AC cable simply plays extremely well with the Utopia. Quite honestly, i'm done with a cable search for these headphones.
i have absolutely no complaints with the sound that i get with this cable. if i had any gripes, it would be with the construction; these are minor but i figure i might as well list them out. i would have preferred a heatshrink/sleeve over the furutech spring extension. the braids in the cable could have been tighter and more even. and lastly, the L and R markings on the headphone end are not lined up with the red dot on the utopia lemo connectors. the other cables i listed above all edge out the AC cable construction wise, but then again, it really is the sound that matters in the end.
if you have the Utopia, the AC cable is really really worth a try!
And I thought I will be the first one to share impressions of the new Silver/Palladium cable. But my cable is on the way since over 2 months now!!! Thank you CoronaI absolutely concur with your comments which also apply to the Arctic Palladium Series. I have been using a two-metre palladium-plated silver cable from AC with Audeze LCD-X, Audeze LCD-4z, and Meze Empyrean (spreading the cost over 3 headphones since they all take mini-XLRs). The AC PS is breath-taking in its absence of sound quality, to my ears. The immediacy and transparency of the music are as though the headphones are directly connected to the headphone amplifier output stages. Like you, thankfully, my quest / experimentation is over. Now to save up for another set for Rosson Audio RAD-0...
I use the same Furman power conditioner. What are your thoughts? Like it?I absolutely concur with your comments which also apply to the Arctic Palladium Series. I have been using a two-metre palladium-plated silver cable from AC with Audeze LCD-X, Audeze LCD-4z, and Meze Empyrean (spreading the cost over 3 headphones since they all take mini-XLRs). The AC PS is breath-taking in its absence of sound quality, to my ears. The immediacy and transparency of the music are as though the headphones are directly connected to the headphone amplifier output stages. Like you, thankfully, my quest / experimentation is over. Now to save up for another set for Rosson Audio RAD-0...
I think the Furman makes a big difference: it lowers the noise floor and I would guess eases the “workload” for component power supplies (internal & external). The Furman was designed by the fellow who designed the Niagara series for AudioQuest. From what I’ve read, silver is a better conductor that copper (6N etc).I use the same Furman power conditioner. What are your thoughts? Like it?
I just bought some silver cables from audio sensibility in canada for my empys/lcd 4s because, like you, they share the same connector, just to try out some silver cables to hear if there is a difference.
Just thought I’d ask: people here talk about dealing with Roy. My emails have been with Val
i hope Val works there too? Any one know how many people are there and if they have dealt with Val too? (Or have i sent my emails and paypal money to someone i should not have)
Thanks - i thought that would be the case but thanks for confirmingBoth Roy and Val work there. I communicate with both via the same email and it's all good.
Is this the platinum? How do you find its sound?
Got it yesterday ,time to enjoy more music
Yes it is the palladium, it is burn in phase ,will give at least 200 hours before proper listening but after the initial hours yesterday i like the instrument separation & clarity (specially detail tunes left & right) ,I did not wanted to take off my headphones to sleep,so yeah it has something magical to keep u excited ,will update as I listen more after workIs this the platinum? How do you find its sound?
I purchased a 10 foot XLR prisma series cable, which cost a very reasonable $315 (reasonable for hd800 cables, that is!)
So overall I'm pretty happy. The cable arrived quickly, and the build time was very good. The quality of the cable is also top notch. Right now I'm going to let it burn in a week or more before giving true sonic impressions.
I too have a Prisma cable currently being built. Since I haven't heard much about the Prisma, i'm looking forward to hearing your thoughts about the cable. I know you want to let it break in but do you have any initial impressions concerning the sound?
