AlwaysForward
- Jan 7, 2017
Thanks for the tip, I will!check out the Sedna Crystal. They are the successor to the Xelastic and are more comfortable IMO.
no pun intendedThanks for the tip, I will!
I'll be doing this comparison at some point. Though I need more time with the AP3 first... And a refresher on how the APP sound since I haven't used them in a more analytical fashion in a while.anyone compared the AP3 to the Pro´s soundwise ?
Hm, looks like they're using adapters. I've never had luck with the adapters as removing them tends to break them. From pictures, the AirPods stick out a lot as well, though that might not be as much of an issue with a custom fit tip on it. You won't be sleeping with them though.ADV. has a custom fit APP Ear Tips project on Kickstarter. I was in until I saw how they fit.
https://www.kickstarter.com/project...section-homepage-view-more-recommendations-p1
I was interested until I saw the price.ADV. has a custom fit APP Ear Tips project on Kickstarter. I was in until I saw how they fit.
Same here! I was super excited, I like the idea and seem like they would function pretty well.I was interested until I saw the price.
i like AP3 more... more volume , less midcentric, better bass and at last not veiled highsanyone compared the AP3 to the Pro´s soundwise ?
