scottm18
- Dec 27, 2016
The problem is well documented here on all firmware versions, including 1.0.1 which mine came with. It's a low-volume backgroud hiss/distortion noise which you wouldn't notice on loud tracks, such as on Thriller. Try listening to a jazz/folk/classical track with quiet bits and the noise is immediately apparent. What's more, the three DSD "ouput modes", ie PCM, DoP, and Native, produce exactly the same sound and noise, so I suspect these are fake settings too. I'm using a fast U3 SD card, with 100MB/s read speeds, and 24-bit 192KHz FLACs play fine, with a higher bit-rate than DSD. The device is unusable with DSD files as stands.
Here's my take: Its a complete joke for DSD...i threw the AP80 aside months ago and will likely give it to a non-DSD using friend. It was perfect in the AP200 so not sure what they screwed up this time but never again will i buy something from Hidizs.
It's really quite a shame as UNDER all that static the unit produces sterling sound with DSD and the built-in program reads ISOs too.
