AP80 - Hidizs next portable Hi-Res music player
post-14687639
Post #2,356 of 3,945
cazone
Paris
Paris
The Volume is variable and so is the gain. Question, why would you want it fixed?
hi,
tried the AP80 as a dac on my MacBook Pro. Works flawless.
And also as a transport for the Mojo.
The Mojo was connected with the supplied short OTG cable to the AP80 in USB "Audio" mode.
Everything works fine there too.
To my surprise the volume control of the AP80 has no effect.
The volume is only controlled by the Mojo (as it should be).
To answer your question,
I hoped the digital-out would be fixed because I hoped the digital stream would bypass the dac section.
(I suppose the gain should either be applied in or after the dac section. Not knowing the AP80s layout).
post-14689218
Post #2,357 of 3,945
titanquests69
Is the hardware (faulty buttons/scroll wheel) lottery issue that bad? I'm bothered by the amount of units with faulty hardware. Contemplating on selling the unit when it arrives and buy an M6 instead. Though, I would much prefer the AP80 over the M6 without the hardware issues.
post-14689242
Post #2,358 of 3,945
oliwek2
Brussels, Belgium
Brussels, Belgium
I had no problem with mine, but I have little trust in the volume control wheel durability, it seems really fragile. Still, sound quality-price ratio is excellent.
But sad, because I still have a stainless steel AP200 that's built like a tank (except for the screen of course). It just lacks a finalised firmware :confounded:
It really makes me wonder : do they plan to design (slightly flawed/unfinished) products to go on with selling new iterations every few months ?
post-14689261
Post #2,359 of 3,945
grs8
Z'ha'dum
Z'ha'dum
QC is really bad, some got doa AP80, one mentioned at ks that the back fall off, loose wheels, faulty buttons, ... and then you should pay p&p back to Hidizs.
They ignore my last mail for over 2 weeks now, no reply, no tracking no., nothing. So I called my cc company and started a charge back, hopefully I will get my money back.
This company is a bad joke.
post-14689358
Post #2,360 of 3,945
oliwek2
Brussels, Belgium
Brussels, Belgium
I guess we'd be amazed by the (little) size of the company.
Sure, communication is awful, and software support is just ... really weak. They struggle to deliver the features advertised during crowdfunding campaigns.
Same experience.
post-14689682
Post #2,361 of 3,945
MisterMudd
TN
TN
Uh oh! My red AP80 has developed a wobbly volume wheel after a month. Makes me wish I bought the Cayin N3 when it was on sale. Won't do a Kickstarter ever again.
post-14689949
Post #2,362 of 3,945
okinear
France
France
Wondering what you are using to tag your music files (under linux)?
Tried easytag: APE tagging does not seem to work (at least for images, the tag gets lost), failed to reset the date tag of MP3 files when it's in the yyyy-mm-dd format, and no support for DSD files...
Is there a better solution under linux (or even under win as dual boot)?
post-14690593
Post #2,363 of 3,945
raiderkilo
Try MP3 Tag
post-14691021
Post #2,364 of 3,945
titanquests69
Damn, this makes me sad. I really wanted this as my DAP. But seeing all these complaints about faulty hardware, I've decided I won't risk it. I'll sell it unopened and buy an M6 instead.
Thank you Hidizs for wasting my time and money. This will be my last Hidizs product.
post-14691099
Post #2,365 of 3,945
kuki_junior
Singapore
Singapore
Im pretty sure this will be my last purchase from Hidizs. Disappointed.
Will just sell it as it is.
What a way to start the new year and end the anticipation for a new mp3.
post-14691257
Post #2,367 of 3,945
GuywhoLikesHIFI
Australia, Victoria
Australia, Victoria
I'm really enjoying mine, MSEB and soundfield are fun features to muck around with, and it sounds great. The build quality on mine also seems really nice. I've used both the leather and silicone case. Battery life is good.
No major problems, when I play a 5 hour AAC 126kbps it takes about 20 seconds to load. Thats all the bad I can think of though. Very satisfied.
post-14692397
Post #2,368 of 3,945
okinear
France
France
post-14692632
Post #2,369 of 3,945
MisterMudd
TN
TN
Since I have the wobbly wheel, is anyone on this thread been in the same situation and tried to return their device? Any results? I am just trying to think ahead in case this whole thing goes bad. Thanks.
post-14692743
Post #2,370 of 3,945
cdmackgreen
I have had the wobbly wheel since the first moment I used it. I have tried forcing it to see if it will come off or get looser but it seems to be OK at that.
The leather case was designed way too tight and the opposite with the flimsy silicone cover.
Apart from that the sound is quite nice.
Wish I could get a silicone cover of the same quality FiiO use to supply with their players.
Just hope the wee thing lasts with good use!
Reactions: MisterMudd
Users Who Are Viewing This Thread (Users: 1, Guests: 7)
  • Top
