Absolutely right, aos.
Assembly is very fast and efficient - from the program's point of view. They are fast and small = efficient.
And with asm, you can do anything your hardware allows you
to do.
From a programmer's point of view, assembly is absolutely inefficient. It takes significantly longer to write, is extremely error-prone (no compiler to help you) and debugging is just hell.
For any mid-size or bigger program, it would be insane to use assembly.
But you can write parts of it in asm if youneed the extra speed.
For small, fast, and/or low-level programs like device drivers and
something like a 64k intro, assembly is still the language of choice.
I used to do quite a bit of x86 programming a couple of years ago.
Small graphic intros, but nothing really good. That was fun back then
ai0tron:
What does 'bloated code' mean? Is the program bigger? Sure. (even without the libraries) But who cares with today's prices for memory?
Is the program slower? Maybe. Today's compilers do a pretty good job optimizing your code, so you might not get 100% speed but very close. On the other hand, a well designed algorithm in C++ beats a bad algorithm in asm. And algorithm implementation/testing is a lot easier with higher-level languages such as C/C++ or Pascal.
Bye
Redwoood
