jlo mein
In some place that's not Canada ....the right of the people to keep and bear arms shall not be infringed.
- Nov 13, 2001
So today in the mail, at long last, after having 7506's for like 2-3 years, I got Beyerdynamic DT 250 velour pads. A big thanks goes out to Rix2357! I had so much trouble trying to order these pads in Canada, and Rix was a big help ordering them from Beyer USA for me and shipping them northbound.
First opened my package. It had been hastily sealed up with Canada Border Services Agency tape after inspection. The tissue paper was all crumpled in a ball and the pads were squished against one side
. Good job CBSA on repacking. Below is a pic of the pads, and you can still see them slightly imprinted from being squished (they have since expanded back to shape).
Next I removed one of the old pads from its driver.
To make removing the foam driver cover easier, it's best to turn the old pad inside out.
Separating it wasn't that hard. Even with the glue holding them together, it came apart cleanly. This is probably from natural hair oils deteriorating the glue haha...
(others have reported the pleather tearing because the glue is too strong).
Next I stuck the foam cover onto the back of the Beyer pad (which I turned inside out). The remains of the glue hold it lightly in place, although it doesn't help much when you try reversing the Beyer pad and sticking it on the driver housing.
This entire operation had been simple so far, and the hardest part (not even that hard), was getting the Beyer pad on the driver housing. Basically you fit the lip of the pad over as much of the driver as you can, and then just stretch the Beyer pads to get the rest of the lip securely on. The Beyer pad is very durable and will not rip when you try to stretch it.
After, you want to make sure the foam cover is seated properly, because its likely that it has scrunched up. I just used a finger to push it in under the pads so that it was lying flat.
It's best to do this process one at a time instead of doing both at once. So just complete the steps for the other side after.
DONE!!! Whole process takes about 20 minutes. It is definitely easier than I thought. Finished product looks much better than with the old pads. One thing I noticed is the velour pads attract more dust and are harder to clean than the pleather.
The new pads are also a little firmer, but will probably break in with time. They can cover a larger ear, as my ear lobes touched the inside of the pleather pad, but not the new velour pads. There is a slight increase in isolation. Even though the isolation increases, they seem more porous, allowing your ears to breathe. It is a lot cooler to wear these pads than the pleather in a warm room.
Sound is pretty much the same, with the mids being just a touch recessed. This will probably go away after the foam in the pads become broken in and squish more with age.
The original instructions I followed are here:
http://www6.head-fi.org/forums/showt...ht=velour+pads
Overall I think this is a worthwhile purchase for V6/7506 owners. With regular use, the pleather pads need to be replaced after 2-3 years anyways (mine were already starting to rip), so why not replace them with velours!
