Android phones and USB DACs
post-8978009
Post #1,156 of 9,413
Toe Tag
I emailed Kingwa the owner of Audio-gd. He asks for our support in reporting which Audio-gd DACs work with USB OTG. At this moment we have one report, that the Audio-gd
NFB-16 (USB DAC/amp) works with the Samsung Galaxy Note II. Here is the full range of products http://www.audio-gd.com/Products-EN.htm and they are of course well regarded here at head-fi.
He can get a cable http://www.ebay.com/itm/USB-Micro-b-male-to-Mini-b-male-data-cable-lead-adaptor-/261135697830 and test his DACs. Many of them are designed with the same "USB32" chip. Danba or anyone who speaks Chinese may want to email him directly. Their contact form lists their email address http://www.audio-gd.com/Contact-EN.htm Of course they can handle English but its faster and more accurate to use Mandarin.
Desktop DAC will not use USB mini B. Can anyone point me at a cable that is USB-micro-B-male to USB-standard-B-male?
post-8978126
Post #1,157 of 9,413
Nirmalanow
http://www.head-fi.org/t/595071/android-phones-and-usb-dacs/1035#post_8959237
Thanks for pointing me to that link. I had a feeling the analog volume control in the Dragonfly would not work, since it is controlled by the system volume in windows. I may try it anyways with my Predator and see if I like the DAC portion. I can also check out the amp on my computer.
post-8978244
Post #1,158 of 9,413
henrylar
USB audio recorder pro works fine after the update today - also for 96/24 files! (Nexus 7, Fiio E17).  Now we just need to convince him to create a simple interface for using it as music player..
post-8978247
Post #1,159 of 9,413
Davy Wentzler
Member of Trade: eXtream Software Development / Audio Evolution
Version 1.0.2 of the USB audio recorder pro app has been released. It should solve the 96kHz issue.
Enjoy,
Davy
Reactions: DanBa
post-8978358
Post #1,160 of 9,413
turokrocks
Enjoy,
Davy
What was I doing???....thank you.
Please keep the updates coming..
post-8978515
Post #1,161 of 9,413
thegrobe
This is pretty exciting news about the "USB audio recorder". I ordered up a USB OTG cable for my Nexus 7 so I can get this set up.
From what i understand, we need some kind of music player app w/EQ to make this whole. It would be great to see this play nice with Neutron
post-8978516
Post #1,162 of 9,413
badhack
Turtle Beach Audio Advantage Micro II confirmed working with optical SPDIF to my Benchmark on Samsung Galaxy S III.
Reactions: DanBa
post-8979038
Post #1,163 of 9,413
DanBa
I will email Kingwa.
A Micro-A to Standard-B cable:
http://www.lindy.fr/cable-usb-micro-a-b-05m/31950.html
USB is an asymmetric protocol in that one participant acts as a USB host (i.e. A-device) and the other as a USB peripheral (i.e. B-device).
The standard USB DAC is always a USB peripheral, the smartphone / tablet has to act as a USB host.
The Galaxy S3, for instance, is a USB On-The-Go device. A USB OTG device can act as a USB host or as a USB peripheral.
Simply put, a USB OTG device like a Galaxy S3 can act acts as
. a USB peripheral when a Micro-B plug is inserted in the Micro-AB receptacle of the Galaxy S3 [regular cable]
. a USB host when a Micro-A plug is inserted in the Micro-AB receptacle of the Galaxy S3 [so-called "OTG cable"]
Micro-A plug, Micro-B plug:
The following cable seller has a right description of his cable:
http://cgi.ebay.fr/1ft-OTG-On-The-Go-Micro-USB-OTG-Cable-Samsung-i9100-Galaxy-Note-SII-XOOM-Nexus-7-/251098049983?pt=PDA_Accessories&hash=item3a769c2dbf
"What is the OTG Cable?
When attached to a PC an OTG device requires a cable which has a USB Standard-A plug on one end and a Micro-B plug on the other end.
In order to attach a peripheral to an OTG device the peripheral either needs to have a cable ending in a Micro-A plug which is inserted into the OTG device's Micro-AB receptacle
or the OTG device itself needs an adapter cable which has a Micro-A plug on one end and a Standard-A receptacle on the other.
The adapter cable enables any standard USB peripheral to be attached to an OTG device."
Make your own USB OTG cable (i.e. convert a Micro-B plug to a Micro-A plug) - Simple:
http://forum.xda-developers.com/showthread.php?t=1806589
post-8979157
Post #1,164 of 9,413
Nirmalanow
After reading some more, I decided to try the DACport instead of the Dragonfly. I will see how a new improved DAC further improves the sound while using this new app.
post-8979420
Post #1,165 of 9,413
DanBa
Enjoy,
Davy
Thanks!
music stored on Samsung Galaxy S3 > USB Audio Recorder PRO player >> ODAC
post-8979574
Post #1,166 of 9,413
lg777
Enjoy,
Davy
I got a Note 2 I317M and the paid version of this app will not detect the FiiO e07k but others have it working.  I have the Behringer UCA202 and it works but this app still does not recognize it.
USB Audio Tester/Recorder detects it but can't do anything with it.
I am making sure I have the app closed before I connect all devices and then open the app.
Playing around some more with my other devices, my Tab 2 7 P3113 works with this app and the E07k!  Great.  My T989D Galaxy S2X also detects the E07k but will not play.  Note 2, nada and that's both ATT and Roger's versions.
post-8979681
Post #1,167 of 9,413
Toe Tag
This could be a source that ships to non-France countries...
http://www.lindy-usa.com/cables/usb/usb-otg-on-the-go-cables.html
But they don't seem to carry their own model 31950 there. I emailed them.
post-8979836
Post #1,168 of 9,413
lee730
BTW what amp are you using? If you are gonna be using a separate amp get the DACport LX and not the DACport.
post-8980487
Post #1,169 of 9,413
Nirmalanow
I am using a Predator amp and I have tried others but keep coming back to the Predator. I also read in a few places that the LX was a little bit better sounding than the DACport with the Amp, but it is true that it would simplify my system to have a single DAC/amp. If I really like the LX, maybe I will try the DACport sometime and consider simplifying. A while back when I was using a computer as my source, I had a Pico and a Predator and kept trying to decide which one I liked better. Finally, I came to the conclusion that I liked the DAC in the Pico and the amp in the Predator, so I kept them both. Then I went to using a Hifiman 801 so no longer needed the Pico, but still fed the signal through my Predator. Now I am using my Nexus 10, so this may be similar in that I am back to having separate source, DAC and amp.
I may someday also try the new HifiM8 for a simpler setup, but as far as I can tell from their website, the DAC in that will require special drivers which may mean it will not work with the USB app for Android.
I use my system as a movable and completely battery powered system, but I do not try for completely portable as I do not travel much, so I do not mind the extra cables and pieces of equipment. I like to strap it all down on a padded laptop desk so that I can easily pick it up and take it outside or into another room. And when I do travel, I will just take the Nexus and my REO iems. Works for me.
post-8980613
Post #1,170 of 9,413
Theogenes
Okay, read this thread with a LOT of excitement last night, and went ahead and bought the app (to thank the developer for his work) and decided to wait until this morning to try it... and it flippin' WORKS!!! Below is my setup:
Verizon Galaxy S3 (running aokp_d2vzw_jb_build-4) > iBasso D6 > HD25-II
Confirmed file playback (so far): 16/44, 24/96
When I first plugged it in, there was sound playing that was obviously some deranged form of the song I was trying to play ("Bleak" by Opeth), so I increased the buffer to the highest setting (16384 frames), and boom-- we're in business!!!!!!
I can also confirm that while both 16/44 and 24/96 will play in the background, they will stutter and pause occasionally when other apps are initiated, etc. Also, when selecting the app again to bring it from the background to being the open application, file playback stops.
It appears that the major hurdle has been overcome in utilizing USB DACs with our Android devices, and I for one am absolutely STOKED!!!! There are still a lot of things to be worked out (improvements to the file player itself being foremost among them IMO), but I can't thank Davy (for birthing this digital awesomeness into the world) and DanBa (for announcing its existence and constantly championing the cause) enough!!!!! You guys are officially my co-favorite people of the day!!
WOOOOOOOOO-HOOOOOOOOOOOO!!!! This is just GREAT!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Reactions: DanBa
Users Who Are Viewing This Thread (Users: 1, Guests: 11)
