Android phones and USB DACs
post-8942226
Post #991 of 9,413
WiR3D
This is what the three connectors on the USB-OTG cable look like:
Just to confirm, I have this cable, it sort of works, but it won't charge my S3 (unless you do the resistor mod) and the problem I have with using it and external power with my E7 is that is still drains the battery of my S3 at a frightening rate of knots. So its not a working solution.
post-8942287
Post #992 of 9,413
haojan
Do you mean GoVibe Martini-U, a USB DAC/amp, rather than GoVibe Martini, an amp?
http://jaben-bandung.com/index.php?route=product/product&product_id=196
http://www.jaben.com.au/products/gvb-martini
Thanks!
=) Yes I meant the DAC/AMP. Tried that and not the Amp only. Thanks!
Reactions: DanBa
post-8943105
Post #993 of 9,413
turokrocks
@ Danba, I want to confirm, that the Galaxy S3 & the Note 2 are the only phones with USB Audio driver support (without any kernel/rom customization) sold?
post-8943325
Post #994 of 9,413
pandemic787
have an iphone so don't need another smartphone but will this work with the samsung galaxy player?
FiiO E07K Andes USB DAC/amp & Samsung Galaxy Note II / S III:
http://fiio.com.cn/product/index.aspx?MenuID=020302
http://www.head-fi.org/t/638910/new-fiio-e07k-andes-information-and-impressions/15#post_8924515
Galaxy Note II / S III > digital USB audio out >> "USB OTG" cable >> FiiO E07K Andes >> headphones
post-8944007
Post #995 of 9,413
NZtechfreak
Phones, yes.
(Archos G9 and Note 10.1 tablets also have it on stock software)
post-8944492
Post #997 of 9,413
NZtechfreak
post-8945481
Post #998 of 9,413
turokrocks
Phones, yes.
Thank you, This G9 looks nice (at least on paper), and all G9 versions support this or a specific version?
And any other players that support this?
post-8945563
Post #999 of 9,413
NZtechfreak
All the G9s as far as I'm aware, apparently noise from the HDD models is unbearable though, so you need to get one of the ones with inbuilt flash storage (max 16GB internal) and then use a micro SD card (up to 64GB currently) to expand the storage. They're not bad, but definitely budget - the screen is fairly poor as are the build materials.
post-8945605
Post #1,000 of 9,413
turokrocks
I was having the exact thought of staying away from HDD version. It will be a nice gift, as to share my DAC/amp!!!
Thanks for the heads-up.
post-8948286
Post #1,003 of 9,413
gidgiddonihah
I am thinking of buying my mother's new AT&T Galaxy SIII for the 50$ she paid on Black Friday and she can have my SII.  The thing is I can't find a way to enable digital audio out.  Is it automatic?
post-8948529
Post #1,004 of 9,413
turokrocks
Just connect it to any supported DAC, and it will auto switch .
