Android phones and USB DACs
Discussion in 'Portable Source Gear' started by nztechfreak, Feb 9, 2012.
401 402 403 404 405 406 407 408 409 410
412 413 414 415 416 417 418 419 420 421
  1. h1f1add1cted
    Should support up to 24/192 and up to DSD128, with DoP function too.
    kawaivpc1 likes this.
  2. cheul
    Just noticed there's a Hibyplayer update.
  3. bmichels
    Any idea where we could get this double angled  micro-USB male cable ?  Much more convenient than a strait cable !!
    thanks in advance
  4. kawaivpc1
    When is it going to be released?
    This one and updated HibyMusic are going to be my favorite!
  5. kawaivpc1
    Yes, they're finally going to fix that dull blue background UI!
  6. seeteeyou
    Unless you plan to perform surgery, they won't be any good for Hugo since its micro USB inputs are recessed
    http://item.taobao.com/item.htm?id=18262361446
    http://item.taobao.com/item.htm?id=36058684046
    http://item.taobao.com/item.htm?id=36453073558
    http://item.taobao.com/item.htm?id=39263703369
    http://www.ttvjaudio.com/TTVJ_Micro_USB_to_Micro_USB_Portable_Cable_p/aat0000200.htm
    Mini on one side and micro on another
    http://store.treoo.com/main/right-angle-mini-usb-to-right-angle-micro-usb-otg-interconnect-cable.html
  7. kawaivpc1
    Can anyone from China tell us when we're going to get an updated HibyMusic?
  8. kostaszag
    I got the new Hiby, v1.2, but the UI is the same. BTW, I would like to ask the developers to add a software volume control. Some cellphones, e.g. my SGS3 can't control the volume on the app with the buttons.
  9. h1f1add1cted
    Should be end of January. If some delay maybe in February, but soon we will get it for sure.
  10. Q Mass
    Seen these?:
    https://www.indiegogo.com/projects/z-ero-the-world-s-1st-digital-earphone
  11. h1f1add1cted
    Yes, please save your money and get real good In-Ears with great sound signature and qualitiy. This tiny built-in USB DAC with a cheap dynamic In-Ear is a good gimmick not more.
  12. kawaivpc1
    it's a good idea. In 2030, we will see Sony, Trac, Samsung making these product with the original sound quality and performance of the current DACs.
    For now, it won't beat real DACs.
    I wish they offer this kind of USB to headphone DAC cable for Shure, Sennheiser, Audeze with quality of Nordost. We may will see this in 2030, not right now.
  13. Theogenes
    Samsung Galaxy Tab 4 8.0 on Verizon (SM-T337V, running Android 4.4.4) is confirmed working with JDS Labs ODAC via USB OTG cable without UAPP. (App tested was Gizmo, music streaming app from JRMC). Volume control on tablet does work.
    Samsung Galaxy Tab 4 8.0 on Verizon (SM-T337V, running Android 4.4.4) is confirmed working with Meier Audio PCSTEP via USB OTG cable without UAPP. (App tested was Gizmo, music streaming app from JRMC). Volume control on tablet does work. (HibyMusic player popped up on plugin and asked to use device, but I did not actually try it).
    Headphone jack on the tablet isn't half bad either.
  14. kawaivpc1
    Cool. I'm going to buy Samsung Tab 4 7 inch. Does it work with Geek Out, Dragonfly, and Explorer 2??
  15. Theogenes
    Not sure honestly, as I don't have any of those devices. If the 7-inch Tab 4 is similar in implementation to mine, I'd assume it works with a variety of devices, but I don't know for certain, of course.
    One aside: Samsung was, at one point, notorious for using lower quality components in their wifi-only tablets than their cellular-enabled counterparts to cut costs in the unsubsidized wifi-only marketplace. Don't know how accurate or apropos that is in this instance, but it might be something to look into before you buy. Just a thought!
