Android phones and USB DACs
Jul 9, 2014 at 1:46 AM Post #5,072 of 9,526
  Use root explorer with root,
Mount R/W to the /system/app folder
Move them there and install.
That's exactly what I did, mate. Installing them one by one would've taken too long. Aint nobody got time fo' dat!
Jul 9, 2014 at 5:56 PM Post #5,073 of 9,526
LG G3 working with Apex Glacier (native player & others)
Jul 10, 2014 at 3:27 PM Post #5,074 of 9,526
Confirmed Samsung Galaxy S4 works with the HRT Music Streamer II+ if used in USB debugging mode and with USB Audio Player Pro https://play.google.com/store/apps/details?id=com.extreamsd.usbaudioplayerpro&hl=en . I did not need to use an external powered USB hub, but tried it both with and without and it works fine. The USB hub I used was USB 3.0 and I did not experience any errors.
The S4, unlike the S3, lacks a USB host stack. In order to add the missing part of the Android OS, you must use a media player that offers its own USB host stack. Gotta make sure you use a USB OTG host mode adapter cable.
Jul 10, 2014 at 4:44 PM Post #5,075 of 9,526
The list of USB DACs working with Galaxy S4 https://docs.google.com/file/d/0B3XYy1FuzDUeRHQwMjBJQ0VqSjg/edit , states the UD110V2 by Stoner Acoustics, as compatible without the need for UAPP. I found that this is not the case, It can only work with the UAPP.
Did anyone succeeded to play it without the UAPP (native player or straming)?
Please advice
Thanks
Jul 10, 2014 at 5:47 PM Post #5,076 of 9,526
Had a System Update with my Samsung Note 10.1 ed. 2014 to Android 4.4.2
Specs: http://www.gsmarena.com/samsung_galaxy_note_10_1_(2014_edition)-5677.php
With a 128gb Sandisk microsd, Geek Out 1000 Confirmed!
Here playing a video.Audio to GO1000.
Playing Yamina on DSD128
Now I can play with my "Media" Tablet!!  Will see how much it will drain its 8200mAh battery.
Jul 12, 2014 at 6:48 AM Post #5,078 of 9,526
  Nexus 7 powered car mod: USB audio out towards a FiiO E17
http://the-gadgeteer.com/2014/06/20/julies-gadget-diary-nexus-7-powered-car-mods/
Why do you have a cable plugged into the AUX/Line in?
Jul 12, 2014 at 6:10 PM Post #5,079 of 9,526
The mod is not mine.
There is certainly some line-level audio equipment at the other end of the cable.
According to the article pointed by the above mentioned link,
"... Chris uses a USB DAC for audio through his speaker system...
... Both Chris and Mike rely on a special 3rd party ROM made specifically for Nexus 7 tablets and car installations. The ROM is called USB ROM and has important features like USB host mode charging, plug&play handler for DAC, Media buttons (volume, play/pause + next track) on nav-bar and much more..."
"USB ROM for Nexus 7
Supported USB audio devices
These are just some of the supported USB DAC's: CM106-F, FiiO E07 + E10 + E17, Hifimediy Sabre, VIA USB Audio Dongle, Behringer UFO202 + UCA202 + UCA222, Syba SD-CM-UAUD, Miditech Audioface2 (PCM 2902), FujitsuSiemens PortReplicator (CM 108), Aune T1 (TE7022), Turtle Beach Micro II, BERESFORD Caiman, Teralink x2, Headroom Total Bithead, Fostex PC-100USB.
Basically all standard USB audio devices should work.
Problems have been reported only with TAS1020B based DAC's."
http://mehrvarz.github.io/nexus-7-usbrom/
Jul 14, 2014 at 3:31 AM Post #5,081 of 9,526
Full-size USB DAC/amp & USB Audio Player PRO: Benchmark DAC2 D, Oppo HA-1
"Sneak Peek! Working on Hi-Res Audio Playback via Android tablet and USB Dacs. USB Audio Player Pro is the key. Currently playing 24/352 from a Dell Venue."
https://www.facebook.com/pages/Everything-Audio-Network/53610321526
Android devices can be connected to the rear-USB input when using OTG cable. USB Audio Player Pro even allows 24/384 via Android devices, which can be decoded by the Oppo."
http://everythingaudionetwork.blogspot.fr/2014/07/audiophile-review-oppos-ha-1.html
Jul 14, 2014 at 6:33 AM Post #5,082 of 9,526
Wicked! Tried DSD?
Jul 15, 2014 at 8:11 AM Post #5,083 of 9,526
Hopefully, he will test DSD on his upcoming review of UAPP.
"For audiophile playback I started off with my Macbook Pro and Audirvana software, and later plugged into a Dell Venue 7 tablet with the USB Audio Player Pro app (separate review upcoming) and a HTC Harman-Kardon Edition smart phone with USB Audio Player Pro."
http://everythingaudionetwork.blogspot.fr/2014/06/audiophile-review-resonessence-heru-dac.html
Jul 15, 2014 at 8:14 AM Post #5,084 of 9,526
A list of stock Android-powered devices reportedly interworking with compatible USB DAC:
stock Android device > digital USB audio out >> USB DAC >> amp >> headphones
http://goo.gl/ksoF0d
A list of USB Audio Player PRO resources (compatible USB DAC, compatible Android devices, ...):
http://www.extreamsd.com/USBAudioRecorderPRO/
A list of USB DAC reportedly interworking with the native USB audio of Android L:
Android device running on Android L > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/x3loEQ
A list of USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy S3:
stock Samsung Galaxy S3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/yBKivk
A list of USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note2:
stock Galaxy Note2 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/Ga1jYw
A list of USB DAC reportedly interworking with the Android-powered smartphone Samung Galaxy S4:
stock Samsung Galaxy S4 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/dIwrqp
A list of USB DAC reportedly interworking with the Android-powered smartphone Samsung Galaxy Note3:
stock Samsung Galaxy Note3 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/7Bvkhz
A list of USB DAC reportedly interworking with the Android-powered smartphone Samung Galaxy S5:
stock Samsung Galaxy S5 > digital USB audio out >> USB OTG cable (ID pin grounded) >> USB DAC >> amp >> headphones
http://goo.gl/zUjud0
A list of USB OTG cables:
http://goo.gl/4JyOe5
USB DAC descriptors:
http://goo.gl/pYJbTu
FAQ:
http://goo.gl/A4dCnP
The basics:
http://goo.gl/MCFY2x
Jul 15, 2014 at 8:33 AM Post #5,085 of 9,526
Thanks for all the effort in maintaining and pursuing this Daniel, much appreciated!
