Android phones and USB DACs
post-9425240
Post #2,266 of 9,413
DanBa
Here's my portable OTG rig I use with the S3:
Galaxy S3 <OTG cable> Belkin Hub <Griffin mini-USB cable> ODAC <Fiio L8> Meier Corda PCSTEP.
Yes, the PCSTEP's DAC is OTG-compatible (and sounds terrific), so the ODAC isn't required.. but I've got a QUICKSTEP (which has no DAC) on the way; which'll seamlessly drop into this setup.  My rig should become even neater since this hub & OTG cable replacement is coming, as well.
The reason I'm using a hub between the ODAC & S3 is cause the S3 returns that (dreaded) "..high powered device connected.." error when the ODAC is connected directly to it via OTG.  For some reason, using a hub (that doesn't even have to be powered) as an intermediary solves this problem (thankfully, a simple, inexpensive solution).
Hahaha nice one Coop....I've actually done a similar mod with the UD-100 here but with a C5 amp instead
That's odd indeed as the my ODAC works just fine with the S3.
My international Exynos 4412 SoC-based Galaxy S3 can also work with my ODAC without using a hub.
Hi!
Galaxy S4 (GT-i9505) working with Stoner Acoustics UD100 :). Not working with Hifimediy Sabre.
The HifiMeDiy Sabre should work with the Galaxy S4 using the USB Audio Recorder PRO app, available on Google Play store. There is a free trial version.
http://forum.xda-developers.com/showpost.php?p=36704343&postcount=75
post-9425999
Post #2,267 of 9,413
FlySweep
Originally Posted by Theogenes /img/forum/go_quote.gif
That's odd... I've used the PCSTEP and S3 numerous times and haven't had that issue. (I've had to unplug and replug a few times when the Android OS looked askance at me, but I don't recall getting that specific message). I'm using the US variant, as I'm assuming you are in Washington. I've got the Verizon version, you?
@Theogenes.. yep, the PCSTEP's internal DAC works just fine with my (Verizon) S3 w/o a hub.  It's the ODAC that needs the hub.
@rckyosho & DanBa.. you both seem to be using an international (non-US) Galaxy S3?  I got the sense the different processor/internals might be why the ODAC works (w/o the hub) for you guys... but I'm not sure.  I haven't been able to test my S3 with a different ODAC, either (to see if something is faulty with mine.. I doubt it though.. as it's always worked just fine in terms of 'sound'/connectivity).
post-9426484
Post #2,268 of 9,413
bmichels
France, Belgium and Morocco
QUESTION; is there on earth at least ONE Android phone (or tablet) with OPTICAL audio out ?   This will really open many DAC compatibility opportunity....
post-9426521
Post #2,269 of 9,413
FlySweep
post-9426717
Post #2,270 of 9,413
bmichels
post-9426908
Post #2,271 of 9,413
DanBa
Google Nexus 7 & HiFimeDIY Sabre Tiny:
http://hifimediy.com/index.php?route=product/product&path=62&product_id=107
http://forum.tellementnomade.com/viewtopic.php?p=141540#p141540
Timur's USB audio Rom-powered Nexus 7 >> USB OTG cable >> HiFimeDIY Sabre Tiny
"What is different from the slightly bigger brother [ HiFimeDIY Sabre]?
- It uses the PCM2706 USB receiver chip in place of Tenor TE7022, which limits it to max 48Khz/16bit inputs
- 12Mhz osc instead of a crystal used in uae23.
- No optical output
- Might work on more devices (Android etc.)
- Volume level controlled by volume hot keys in Mac OSX, does not appear to work in Windows
What is the same?
- Sabre ES9023 chip
- 2.2Vrms output
Which one should i get?
The new Uae Tiny is almost as good at a lower price. If you don't mind paying the additional dollars, go for the uae23 version (Hifimediy Sabre DAC). If you want to save a few bucks and don't need 96/24 this newcomer should be a good option."
post-9428274
Post #2,272 of 9,413
DanBa
post-9429206
Post #2,273 of 9,413
DanBa
Sony Xperia Z & AudioQuest DragonFly including the Sabre ES9023 conversion chip:
http://www.stereophile.com/content/audioquest-dragonfly-usb-da-converter
http://xperiarx.blog.fc2.com/blog-entry-13.html
Xperia Z using USB Audio Recorder PRO >> USB OTG cable >> AudioQuest DragonFly >> Sennheiser IE800
Google translation:
"...  I think this is the best performance as a portable device...
the turn of the Walkman SONY another product development in the future of SONY is a concern, but read-only portable device with a USB digital output in the domestic manufacturers for some time does not come out still I think or not such information is error free. In thinking of the old phrase copyright organizations in Japan, it would not be stopped decline of the music industry in this country. Most, or that there is no matter to me are not interested at all, such as Japanese music. Had better perish without permission. Anyway, for the environment surrounding sound global, I have entered the era of high bit rate digital output by surely. In addition, USB audio portable equipment was the monopoly of the iPod as well, has been approaching a time when it can be easily machine on Android in the future.Feeling that likely to be the first year to be 2013."
post-9430485
Post #2,274 of 9,413
LyPForever
Member of the Trade (reseller)
Google translation:
Can you use volume control on your Xperia Z ???? , damn I love the dragonfly so much but I decide to end up with another one because I heard someone can't use volume control on their galaxy note 2 and s3 ???
post-9431424
Post #2,275 of 9,413
DanBa
Sorry, it is not mine. It belongs to a Japanese guy.
You could post your question on his blog. I'm not sure if he can understand English.
post-9431745
Post #2,276 of 9,413
hardy820
Hong Kong
Hong Kong
It's so sad that the FiiO E17 works with S4 (confirmed by XDA members here : http://forum.xda-developers.com/showpost.php?p=41229169&postcount=12)
but not the E07K which was working with S3. (confirmed and used by myself)
Both the 9500 3g and the 9505 4g doesnt work with the e07k,
Having the same situation that playing music will quickly fast forward with no sound output.
the 9500 even worse that once i plugged in the e07k it starts to crash the system. (maybe because it cannot output audio properly?)
However it's working with USB Audio Recorder if you stop the system outputting audio signal (mute) BEFORE you launch the app.
hope somebody can fix it :frown:
Reactions: DanBa
post-9432661
Post #2,277 of 9,413
DanBa
post-9433340
Post #2,279 of 9,413
gordec
HTC One and Samsung Galaxy S4 both work with Leckerton UHA-6S.MKII via USB-OTG straight out of the box. I got the One first then returned for the S4. This is AT&T version to be specific.
post-9435462
Post #2,280 of 9,413
kimvictor
Users Who Are Viewing This Thread (Users: 0, Guests: 5)
