Android 4.1 FINALLY USB Audio
Jun 27, 2012 at 3:55 PM Thread Starter Post #1 of 28
ksvieb
Looks like golden times for audiophiles:
http://developer.android.com/about/versions/jelly-bean.html
USB Audio
USB audio output support allows hardware vendors to build hardware such as audio docks that interface with Android devices. This functionality is also exposed with the Android Open Accessory Development Kit (ADK) to give all developers the chance to create their own hardware.
Jun 27, 2012 at 11:29 PM Post #6 of 28
Elythor
Yes finally!
So far there's no indication that they are using a standard for digital output...it could be its own standard with API calls through Android Open Accessory Development Kit
But nonetheless..this is great news.
EDIT: Just looked up the ADK website http://developer.android.com/tools/adk/adk2.html
To play audio over USB, you must use a device running Android 4.1 (API Level 16) or higher:
  • Plug the AC power adapter into the ADK.
  • Connect the Micro USB AB connector (small, rectangular plug) to the Phone port on the ADK board.
  • Unlock your Android device and connect the Micro USB B connector to your device. Note: Your device must support Android USB accessory mode. Devices that support this mode include Google Nexus devices.
  • On the Android device, you should see a prompt to connect to the ADK DemoKit 2012, select Cancel and allow the ADK to connect as a media device only.
  • Navigate to an application that plays music or other audio.
  • Play a song or sound and listen to it on the ADK speaker!
Note: When using the ADK with a USB connection to an Android device, make sure the AC power adapter is plugged in. A USB connection to a computer does not provide sufficient voltage to power both the ADK and a USB connection to a device.
So from the looks of it...your DAC must support the latest ADK.
Jun 28, 2012 at 1:06 AM Post #7 of 28
jasaero
Thanks.  Seems to be described further here also.
http://developer.android.com/tools/adk/aoa2.html
Seems to be a pretty standard USB audio thing, but seems maybe the DAC or device needs some capability to send a usb control request to get the phone to start sending data to the dac??
Seems like maybe existing stuffs might work if you had a hacked rom to toggle this accessory mode manually?  If we were really lucky this USB Control request that is needed to start the streaming mode is more standard than it seems??  Regardless it really seems were are just a minor USB DAC chip tweak away from android phone USB Audio goodness at worse.
Jun 28, 2012 at 11:47 AM Post #8 of 28
Elythor
Nice find!
I guess the only way to find out is to plug a USB-DAC onto the Galaxy Nexus (w/ 4.1) and see what happens
Too bad I have a Galaxy S2 and Samsung probably will not be porting 4.1 over to it any time soon. Can only hope the XDA community can release something useable soon.
Jun 28, 2012 at 3:06 PM Post #11 of 28
IEATTIGER
Confirmed that fiio e7 does not work with the new android 4.1 os on a galaxy nexus toro.  I just tried it and have played around with it for a while trying to get it to work.  This is a huge let down for me.  Looks like I might be spending the money on that galaxy S3 after all.
Jun 29, 2012 at 1:40 AM Post #13 of 28
proton007
Would this work with the original SGS? Mine's still working without issues, except for the free dock that I can't get to work on it  :frowning2:
If 4.1 is ported to work with SGS (Cyanogenmod etc), you may have a chance.
Jun 29, 2012 at 12:51 PM Post #15 of 28
jasaero
Yeah, I think we will need the source released to get this working on legacy DACs maybe. Toro could have issues just because we need 4.1 proprietary files though. GSM might already work if some of this is proprietary file related as I figure its update hit some of those. It may take DAC updates without hacked AOSP built Roms also. Seems we are closer than ever though.
