Amps that can drive the HiFiMan HE-6 planar headphones
Jan 19, 2022 at 9:41 PM Post #5,716 of 5,759
screwdriver
FLorida
I wanna post an update about amps . I used to own og he6 with f1j nelson pass a while back and since sold it , best combo for me. I now circle back using he6se v2 and I was reading how the smsl sa400 ($659) paired well with a susvara and an he6 . so I gambled and bought the next amp lower than the sa400 smsl . it's called smsl ao200 and it's a class d amp for $279and I pair this with soncoz sgd1 , speaker taps he6se v2. it brings a very nice full sound once broken in and it's very airy. bass is full . I use volume 28 out of 70. the amp has a built in tone controls which u can. bypass or use . all in all if u have a he6se v2 and need a budget amp for it the $279 ao200 will work well.
Jan 20, 2022 at 10:35 AM Post #5,718 of 5,759
swva
I own the Monolith THX Dac Amp with dual THX 788 modules. Would this set up be powerful enough to drive the HE6se v1/v2? The total power for balanced output is 3.1 W at 32 ohms, unbalanced SE at 1.3 W at 32 ohms.
The Monolith does a great job with my Focal Elex and Sundara headphones connected with an unbalanced SE cable.
Jan 20, 2022 at 2:51 PM Post #5,719 of 5,759
randytsuch
I just purchased a Nelson Pass ACA Class A Amp. I did not assemble it, someone else did. I'm using it with my RME-ADI-2 DAC as the DAC and to control the volume. I'm running the HE6 SE right off the speaker taps.
As for the Dick Olsher adage "The First Watt Is the Most Important Watt" And "Who cares what an amplifier sounds like at 500 watts if it sounds like crap at watt one".
There is something to that, because this Nelson Pass amp is out performing my Master 19 in sound quality. This is really nice.
I built a ACA a while ago, and use it for my HE6 SE's. Off the speaker taps. Sounds great to me. I do plan to upgrade, to a bigger, better Pass Class A amp.
Every once in a while, used ACA's come up for sale at diyaudio.
Randy
Jan 20, 2022 at 7:04 PM Post #5,720 of 5,759
JoeTho
USA
Randy
Jan 21, 2022 at 5:38 AM Post #5,721 of 5,759
musicinmymind
you need 10W at 50 ohms, I am referring to OG HE-6 do not have HE6se
Jan 21, 2022 at 3:39 PM Post #5,723 of 5,759
Andrew_WOT
10W seems like very excessive, this is my amp spec and I can't go past 12 o'clock in balanced drive when listening very loud.
This is SE, may be original were different, but from what I've read new one even less sensitive. (link)
index.php
Jan 21, 2022 at 10:36 PM Post #5,725 of 5,759
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
Continuous power draw is probably no more than a watt or two for most people, but those transient peaks can easily shoot it up. Every 3 dB is another x2 power. Even a modest +12 dB peak in the music will pull x16 more power. A strong 21 dB (not uncommon with percussion for example) peak is x128 the power, and now we're suddenly into triple digits
This is not to say that one *must* have gobs and gobs of power, but it's deceptive how quickly those power requirements go up. If you don't have it, well maybe it mushes some of those transients, maybe if it's a soft clip you don't even notice and it adds a nice character to the sound which might otherwise by harsh, I dunno.
As with all things, there are drawbacks to the big amps too. Higher noise floor, sacrificing nuance for muscle, blah blah blah. I've literally used kilowatt amps on my HE-6 for fun in the past.
Jan 22, 2022 at 12:21 AM Post #5,726 of 5,759
Andrew_WOT
Feb 4, 2022 at 10:48 AM Post #5,728 of 5,759
jmillar
Madrid
One of the worst I've heard was THX789. It just sounded terrible. It has several Watts, but number of watts doesn't mean the HE-6 will sound right out of it. Supposedly, is measured with hardly any distortion that people calls it "wire with gain," but it just sounds bad that I could care less about it's measurements. Well, if "wire with gain" sounds like that, then "wire with gain" isn't what I'm looking for.
Well, it can get worse than THX789. lol. You can try to drive it out of a portable amp.
Watts isn't the key magnitude here. Volts and Amps are more relevant. The HE-6 is mid-low impedance so it is current hungry. Possibly the THX can't cope with it.
But in any case feed the amp balanced input (XLR) at decent voltage: (4-5 V) and use balanced headphone output.
Feb 4, 2022 at 11:17 AM Post #5,729 of 5,759
SilverEars
I really have no idea what you are talking about.
Power = V*I
Sensitivity = SPL/W
It's just one way to refer to the different parameters. And we don't keep mentioning power for no reason. The spec states 83 dB/mW
The important bit to look for in an amp is the power output at different impedances.
Feb 5, 2022 at 4:37 AM Post #5,730 of 5,759
sajunky
South Africa
Power = V*I
Sensitivity = SPL/W
@jmillar is right about power delivery. It was expressed in the way that technically fluent person would object, but it is actually an issue. Volts or Amps are also important in the way how it is delivered and whether the amp react to the resonances of the object. Especially amps that use negative feedback to reduce harmonic distortions can react to such happenings on the output and need much higher/lower internal impedance ratio than amps with zero negative feedback to deal with the issue.
