Amps that can drive the HiFiMan HE-6 planar headphones
Aug 30, 2016 at 7:23 PM Post #4,726 of 5,703
TheGadaffiDuck
British Columbia, Canada
Have approximately $1500 to spend on amplification for the HE-6. Currently using an old Yamaha DSP-A2070 receiver from the 90s which puts 80W into 8-ohms.
It does the job but wondering if a Mjolnir 2 or Krell KAV-400XI would be better?
Found a used Krell for £1200 boxed with remote etc. just trying to figure out what the best bet would be for making these headphones sing!
Also is the new Hifiman HE-1000 as hard to drive as the HE-6? Just want to know if my investment in a good amp will be useful once the HE-6 eventually gives up the ghost.
A dedicated power amplifier would probably prove better than a receiver but i read earlier a lot of people really loved the sound out of some vintage receivers with their HE6s. I dont know much about Krell's stuff but they are uber expensive and well received. In Schiits line, Jude recently made a video mentioning the HE6s comparing the Mjolnir, Ragnarock, and Jotunheim amps. Basically the former 2 have more power, but the Jotunheim is more forgiving of a presentation vs the sometimes too bright sounds of the other 2. If you have speakers, HE6s, and 1500 to spend, Ragnarock would be your best bang for an all in one, but the Jotunheim looks so much better IMO
Aug 30, 2016 at 9:16 PM Post #4,727 of 5,703
Armaegis
Modern Modder Man of Manitoba
HTML... uphill, both ways!
If you have $1.5k burning a hole in your pocket, yeah sure go shop around. Krells and Brystons are good.
If spending that much money is a significant expenditure, then slowly back out of this thread and be happy with what you've got.
The HE-1000 and HE-x are much easier to drive than the HE-6. Don't worry about obsolescence though. The headphone landscape is changing far too quickly to make long term plans.
Aug 31, 2016 at 8:16 PM Post #4,728 of 5,703
dogbait
Heheh, amen.
The kind folks at Schiit EU loaned me a Mjolnir 2 + Gumby.
I warmed the Schiit stack up for 8+ hours. I then volume levelled the MJ and my Yamaha speaker amp so that their volumes were equal. In comparing the two the Yamaha has it by a hair - a little easier to listen to and a little more heft in the bass notes. The MJ has a little more resolution which I'm guessing is due to its lower THD (0.005% vs 0.015%). But to be honest it's so damn close that if money were no object I'd get the MJ purely for the compact size and looks.
I can't really imagine anything trumping a Mjolnir short of say a Bryston B100/B135 or something equivalent. All in all, the Mjolnir 2 impressed me greatly. Top marks.
(need to find someone to lend me a Bryston stack now... :wink:
Aug 31, 2016 at 10:01 PM Post #4,729 of 5,703
Armaegis
@dogbait
Here's a couple Brystons in EU... (just found them searching online; I can't actually read those)
https://www.ebay-kleinanzeigen.de/s-anzeige/bryston-limited-b60r-integrated-amplifier-top-zustand/428725857-172-1432
https://www.hifi.nl/tweedehands/10007959/Bryston-B-60-Integrated-Amplifier.html
http://www.audio-markt.de/_markt/item.php?id=2671921517&audioauktion=08fc75fec0542492a15d3c5677b6f41b
Aug 31, 2016 at 10:23 PM Post #4,731 of 5,703
Armaegis
I'm sure there are plenty of EU based pro audio amp makers out there that aren't common here... there's Lab Gruppen and MC2 Audio off the top of my head.
You can probably find Hypex stuff much easier as well (look for the NCore modules).
Sep 5, 2016 at 10:49 AM Post #4,732 of 5,703
MrTie84
Hey First Watt guys I've been trying to search the thread but coming up a bit empty handed, Aleph J, yes or no on the HE-6? 25 watts, but it's def more current limited than the F5, so I'm unsure. Describe the flavor to me if you've heard it.
Sep 9, 2016 at 7:12 PM Post #4,735 of 5,703
musicbuff
I have a vintage Yamaha Natural Sound stereo amp A-450 bought around 1980 brand new and it still works well.  It has 200 watts per channel per 8 ohms and 60 watts power out.  Would it be a good speaker amp?  If so how would I go about connecting the HE-6 to the speaker terminals?  If so make it simple, I am not electronically savvy
Sep 9, 2016 at 8:30 PM Post #4,736 of 5,703
Armaegis
Hey peoples, there are a couple Bryston B60's floating around on the used market at decent prices right now. Definitely worth checking out; you get all the goodness of the 2B, plus preamp/volume control. Some of them are also the newer SST versions which have improved output devices (worth it; I had mine upgraded).
Sep 9, 2016 at 9:35 PM Post #4,738 of 5,703
Oregonian
Oregon
It will make a GREAT speaker amp - especially for the HE-6.  I run my HE-6 out of the speaker taps of a Pioneer Spec 2 amp @250wpc.  You will need a XLR-->speaker tap adapter.  Available at many cable houses - Headphone Lounge made me two of them for two different systems.
Sep 10, 2016 at 9:41 PM Post #4,739 of 5,703
musicbuff
Here's the back of my amp.
Saw this
http://www.audioadvisor.com/prodinfo.asp?number=HMHEADP
and wondered since it's made for the HE-6 if I could just purchase this and connect it directly to my 250watts/8 ohms power amp?
If yes, what precautions would I need to take besides making sure the volume through my preamp is zero before adjusting the volume up (with the headphones on my ears, of course).  Would I need to disconnect my speakers?
Sep 11, 2016 at 4:04 AM Post #4,740 of 5,703
ohhgourami
Saw this
You could drive both in parallel if you want.
