Amps that can drive the HiFiMan HE-6 planar headphones
Feb 22, 2011 at 7:08 AM Post #31 of 6,061
Apologies in advance if this is a dense question, but how are you guys connecting headphones to a speaker amp... do they come with a cable that does this or is it a DIY effort?
I have an 18w class-A valve amp which might work well (http://www.fat-man.co.uk/docs/product_07/iTube_182_with_ValveDock.shtml), it has a 4 and 8 ohm taps...so I guess maybe the 8ohm would be suitable, I'm not sure how the impedance-matching would work with the HE-6's 50ohm load.
I also noticed some comments on the MF xcan sounding good, I have an M1 HPA, which should be at least as powerful by my understanding, would be interested if anyone has heard this combo?
Feb 22, 2011 at 8:38 AM Post #32 of 6,061
You need to get an adapter that is speaker-wire to XLR connector, and your headphones either have to have already been wired for balanced, or you have to rewired them for balanced.
Feb 22, 2011 at 9:32 AM Post #33 of 6,061
Thanks. Specifically with refernce to the HE-6 - are they wired correctly and only in need of the speakerwire>XLR adaptor?
Feb 22, 2011 at 9:59 AM Post #34 of 6,061
Yes, because the HE-6's are already terminated in a 4-wire, 4-pin XLR connector.
Apr 3, 2011 at 1:20 AM Post #35 of 6,061
NFB-10ES FTW!!!!!!!!!!!!
Apr 7, 2011 at 9:25 AM Post #36 of 6,061
Hi Milosz --
I feel you're selling the AMB M³ a bit short.
For low impedance cans you could increase the M³'s quiescent current to 160mA at 24V, I'd be surprised if that wouldn't take away the clipping. With 36V rated opamps (e.g 627/637) and a 36V linear power supply, it could swing enough voltage for the highest impedance cans as well.
The versatility and price/quality of the M³ is quite remarkable.
Apr 7, 2011 at 9:43 AM Post #37 of 6,061
I used the violectric v100 with my he-6 and it performed quite well. Of course a speaker amp is ideal, but the v100 drove it with great bass depth and control. I compared the v100 with musicman59's WA5 and found the v100 drove the he-6 almost as well. It was perhaps missing some of the dynamism the Woo could give, but the difference was quite small. I also have a lyr, but unfortunatly it's across the planet from me. When I can try it I'll let you know!
