AMPLIFIER FOR PRO 750
Jan 1, 2010 at 3:37 PM Post #2 of 2
Congratulations on deciding to go with the Pro750. It is a fantastic headphone; however, it is an extremely accurate headphone and therefore I would recommend that you use quality components or otherwise you will suffer from hearing accurately how bad your other pieces of equipments are.
For an amplifier, I could recommend no less than a used Meier Audio Corda Move. I would not recommend going with anything lesser than that. If you are thinking of using $40 amps, please consider some other headphones. I am serious....
