PurpleAngel
So what happens when a set of headphones isn't driven properly? Is the issue just in volume as it relates to distortion, or does it also significantly affect soundstage and frequency balance?
Interesting. Are the 250-ohm different in that regard? Most reviews say people prefer 880s, unless they want the 580 signature.
Not sure there is one clear answer for what headphones sound like when not driven properly.
Normally the DT880 provides a well balanced sound, slightly on the bright side, does it sound this way to you?
You could try this cable (Hosa CMP-153), to connect the 18i8's line-output, to the line input on the E7, see how that sounds.
https://www.sweetwater.com/store/de...53-3-foot-3.5mm-trs-to-dual-1-4-inch-ts-cable
The DT880 250 and DT880 600 sound very close, the 600-Ohm sounding slightly better.
