Amp for long cable from DAC to home stereo?
Nov 12, 2008 at 12:46 PM Thread Starter Post #1 of 4
Traddad
I'm running ~30ft of good quality cable from my computer/dac to my home stereo in another part of the house. Would it be better to put a pre-amp on the DAC end to boost the signal for such a lomg run?
Nov 13, 2008 at 10:41 AM Post #3 of 4
FallenAngel
Toronto
A 30-ft IC is OK, make sure the output stage of the DAC can handle such a capacitive load. A pre-amp would work just perfectly for this purpose.
Originally Posted by royewest /img/forum/go_quote.gif
Isn't this what balanced cabling is all about?
Nope.
Nov 13, 2008 at 3:16 PM Post #4 of 4
Pars
Can Jam '10 Organizer
Yes. Balanced interfaces reject common mode noise much more than a single-ended interface as you are currently using, due to the 180 degree out of phase + and - signals present. Balanced in the headphone world is used more for its double the voltage swing vs. a SE amp than for its noise performance.
