Yukster
- Jan 30, 2004
I have been having some problems, and wondering if all of you can shed some light some of the problems I have been experiencing.
Over the last few years, I have switched from a Mini Disc - Pimeta amp setup to a iPod - DAC/Amp setup, specifically the Dr. Dac 2 DX and a iPod Classic through a Onkyo ND-S1 through HD650 headphones. The Dr. Dac isn't that well known on the Head-Fi, but its a DAC that accepts optical, coax and USB digital inputs, and outputs it to either a line out or via a headphone out. Its quite popular in Japan, since you can replace the opamp, and you can buy it in most of the large electronic shops.
The problem that I am having is that the sound out of the ND-1S is very different between the optical and coax, and both the optical and coax sound horrible. Through the optical connection, everything sounds dull and flat with average soundstage. Out of the coax, the treble and bass sounds quite lively, but there is no instrument separation, and the sound seems like everything is pushed together. The soundstage is nonexistent, the music that is coming out of it sounds like everything is running into each other.
I also tested the Dr. Dac with optical cables and an older Sony Discman, and the sound was pretty dull sounding.
The weird thing is that when I connect the Dac to my PC via USB, and using Foobar and WASAPI the music sounds perfect. It can't be the music files, since I am playing FLAC files in Foobar, and for the iPod, I take the FLAC files and re-encode them to Apple Lossless, through dbPowerAMP.
The cables that I use are not exotic by any means, but they are not freebie cables either. Both cost between 2000 to 3000 yen ($20 to $30).
I am not sure how to solve this issue, except to replace the Dr. Dac with something else. I really don't want to do that since, I have some nice opamps in the Dac (Muses01 and Muses02). Could it be my power source? Could it be that I need better cables? Is my DAC and ND-S1 messed up?
Any suggestions or advice would be much appreciated.
