skyskraper
- Aug 5, 2004
do they do tube matching at ae also?
Originally Posted by skyskraper with a well tuned discrete buffer is it possible that the offset would be low enuff that the caps could be gotten rid of entirely? ![]() |
Originally Posted by drewd I thought I'd also speak up about output cap selection. I've got two hybrid amps running now, one built with budget parts (Panasonic caps and pot) and the other with semi-pricy parts (Elna Silmic-II and Wima caps, ALPS Blue Velvet pot). There is a difference and it's noticeable. A I have to say that if it's noticeable with my ears, then it's probably a big difference. The second amp, with the expensive parts sounds better, with quite a bit more detail and sense of space. That being said, the budget amp sounds pretty darned good. After poking around with amp number three, I believe that the significant difference lies with the output coupling caps, which shouldn't be too surprising. The Panasonic FC and poly caps just don't perform as well as the Elna Silmic-II and Wima poly caps. Amp number three with Panasonic caps on the power side and the Elna/Wima combo in the audio path sounds just as good to me as the full Elna/Wima amp. That's with 12FK6 tubes and a STEPS running at 30V. Grid bias is at 13.8V. My off the cuff feeling is that if your aim is to get into a tube amp on the cheap and you want to go with the budget parts, you'll do just fine here. If you want to spend a few dollars extra and go for the upgraded output caps, you'll get the most bang for the buck there. If you go all out and outfit the entire amp with them, I don't know if you'll hear the difference - but I'll be the first to point out that after spending 10 years duking it out with US Navy sonar systems, my hearing isn't what it used to be! -Drew |
Originally Posted by drewd After poking around with amp number three, I believe that the significant difference lies with the output coupling caps, which shouldn't be too surprising. The Panasonic FC and poly caps just don't perform as well as the Elna Silmic-II and Wima poly caps. Amp number three with Panasonic caps on the power side and the Elna/Wima combo in the audio path sounds just as good to me as the full Elna/Wima amp. That's with 12FK6 tubes and a STEPS running at 30V. Grid bias is at 13.8V. |
Originally Posted by Finch&Music 1. In the output stage there is one resistor and one combined cap functioning in the signalpath. Is it possible that also the resistor quality is of influence? Could you try already some different resistors of more than middle of the road quality? |
Originally Posted by dsavitsk fwiw, I exchanged the 100uF elna's for 470uF Nichicon Muse KZ's (from Percy) and it made a pretty big difference. Whether the difference is the size or the brand, or both is anyone's guess, however. The point, however, is that Drew is right that the output caps matter. |
Originally Posted by drewd To figure the cutoff frequency on your own, the formula is just 1/RC, where R is the impedance of your headphones and C is the capacitance of the output capacitors. |
Originally Posted by amb drewd, you forgot something in the denominator... the formula should be: f = 1 / (2 * pi * R * C) For a 100uF output cap, -3dB point is 5.3Hz for 300 ohm load or 49.7Hz for 32 ohm load. For 470uF, it's 1.1Hz and 10.6Hz, respectively. |
Originally Posted by Voodoochile As for the PSU, while a wall-wart is okay, a decent linear makes a marked improvement. Jamont mentioned this earlier also. I found an open-frame linear (Sola or Power-One) 28v PSU for about $15. These retail for closer to $70, and they show up in surplus and on ebay fairly often. |
Originally Posted by blip ... I guess I could always use the millet as a pre-amp for another gain stage... Like maybe for my pimeta or some kind of simple voltage gain stage. |
Originally Posted by drewd That's with 12FK6 tubes and a STEPS running at 30V. Grid bias is at 13.8V. |
as far as making the amp work as a preamp, you should not have to do anything to it. The amp should do a great job driving a high impedance load like a power amp. Output cap selection becomes pretty easy - anything over 47uF will work just fine. Pete briefly touches on that in the AudioXpress article available on his web site. |
