Alps Blue pot motor strong enough for a second pot?
post-1448889
Thread Starter
Post #1 of 1
Garbz
Ok in my ever running quest to stump the head-fi community I have a new question for you:
I am about to upgrade my Dynalo to a Dynamid, and in the spirit of keeping costs down, and not sacraficing the current remote control'ed volume controll which I dare not live without, i'm going to add another Alps Blue Valvet (RK27 for the numbers people out there).
The method is easy simply mount them side by side slot a gear on each and a gear in between. Or turn one around and don't mount another gear inbetween. Either way the point is the same.
Rotational torque of these are 5-35mN.m
Rotational torque of the motorised are 15-45mN.m
However I can't find anything which says the torque of the motor. I know for a fact though that stopping torque is 900mN.m so the motor is not stronger then that.
Will it work? I'd hate to spend $30 on a pot I can't use
