This is interesting, since the famous uber-reviewer criticises them also for the vocals, especially in some high pitched vocals – and the same bump at 4-6Khz is considered responsible for a lack in separation when orchestral textures become complex.
In part, these things are true, but I happen to enjoy these cans immensely on vocal music and orchestral music as well. Smaller instrumental ensembles are where it excels.
Far from perfect – how can they be? – they are more dynamic and emotionally involving than the competition in the same price range. The level of detail and the naturally of the presentation are simply great. They could however separate layers better when the music has a large number of independent strands (Richard Strauss's large works, for instance).
With a chord mojo there is no harshness/overt brightness.
Roberto
I try different amps and find that if you use a warm sounding amp with K812, it will lose much separation. The extreme case is the Element of JDS, which sounds ridiculously bad with K812, even worse than iphone-earpod combination. With other warm-sounding amps, such like Schiit Lyr 2, K812 doens't sound bad, but indeed you won't find good separation when you listen to complex orchestral works. I will describe that sound as 'stuck together'.
However, if I connect my K812 to Audio-gd NFB-11, things are different. NFB-11 is a natural sounding, or maybe a little bit cold sounding integrated amp. It has highest resolution while it is criticized as clinical. On NFB-11, K812 becomes the most refined headphone I've ever heard. The sound is extremely natural and colorless, and the separation is even better than HD800. Someone may not like the colorless or emotionless sound, but for me, the only pity is that NFB-11 doesn't provide a huge sound stage.
I say I prefer vocal music than orchestral music on K812, which is only about taste, not quality. For example, of course HD800 has better quality than HD600, but I like more the orchestral musics on HD600.
It's easy to notice the bump you said, but I don't think it is responsible for any imperfection. It makes the sound bright, not harsh.
