machoboy
- Aug 20, 2012
Been away from HF for a while... Just ordered some of the 612s. I'm crazy about the 702s.
Great review brookoo. Thanks for it! I am deciding betwen k612, k712, q701 and k701/702. I have a stereo amp pioneer ad 30 k and a reciever yamaha. I think both of them have enough juice to fully drive every of the akgs mentioned above, or am I wrong?
I listen to most every kind of music, so I need a neutral headphones. From the review by brookoo and from the discussion I am ready to buy k612.I just hope the soundstage wont be very much smaller as by other headphones mentioned above.
If you want neutral and natural look at the K612 and also try the K712, K7XX, and K702 65th Anniversary if able. I personally stopped using the K612 after getting the K712. I found the K701, K702, and Q701 sound unnaturally bright and have some funkiness going on in the soundstage.
i listened for anhour, or so to 701,702,712,612 and 812. I decided to buy k612, because of the neutral sound and prise. 812 are the best sounding, 712 are more bass oriented and fuller in all dimensions as 612, but they were burned in and 612 not and I thought they werent as much better as the cost difference - 339 euro against 126.9 euro. I give the 612 a chance to burn in and see, if I will be ready to spend twice the price for 712, or stay with 612, which are more neutral with less bass and not so full, but althoug very good sounding for the money.
701 and 702 are good but not better for me as 612.
I will listen to 612 and write, if my decision was right, or not.![]()
I plan on buying a pair of k612's this summer but dont really have any amps besides a fiio e6 and a sony multimedia receiver thing. What amps would be recommended under $200 (preferably closer to 150)? I'd also really like to try a tube amp.
edit: this is the sony receiver http://www.amazon.com/Sony-MHC-EC55-Component-Discontinued-Manufacturer/dp/B000MXLCM0
any Pioneer A stereo amp. I have A 30So what amps under 200 would recommended for solidstate instead of tube?
It's a shame, I can't really seem to find either of those in the US. I probably should have mentioned I live in the us.
