vid
- Jan 5, 2005
Why not? Lower the 100 Hz hump if your pair has one while you're at it.
The Sextett, as well as many other AKG dynamics from that era, suffers from massive ringing in the treble. It's part of the Sextett identity. Lower the treble and/or boost the bass with an EQ to warm up the sound.
Serious ringing.
I can guarantee you they have ringing.
No idea how it connects with sibilance in actual music. Chances are you'll have a harsher sound if the driver rings in the treble - some people like that type of sound, even.
My K 250 have the typical Sextett ringing pattern - at 4, 12, and 15 kHz or so - and I prefer them for metal.
I'd say it's more likely that you're one of the many who don't find the Sextett ringing offensive. The 4 kHz ringing, for instance, is absolutely massive nonetheless and has been observed on any vintage K 240 you'd care to name; even the K 340 has it (heck, even the K 400, though less than those older models). Where you might find variance is in the upper treble ringing - my K 250 for instance has three spots of ringing there while the K 241 has two, and the only EP Sextett I've seen measured for this had two as well.
Would be interesting to see the K400 graph.
