The saga continues...
New optical cable same problem out of Airport Express, this time a short 1 metre cable.
but... hooking this cable straight into the mac’s optical works fine, no buzzing, no dropouts (the previous faulty cable didn’t work out of the mac).
A while back I sent a query to Cambrigde Audio technical support, in regards to Airport Express>840c here’s their response:
We have been investigating this over the last couple of weeks. Our engineers and those at Anagram Technologies have identified a 'quirk' with the optical output of the Airport Express.
Basically, the Airport does not output a smooth SPDIF clocking. Every now and then, the Airport will sporadically adjust its output clock to track the desired sampling rate.
These adjustments are very sudden and are the cause of the noise described.
This is not something which could have been foreseen. Our engineers are however, working towards the possibility of mitigating the effects of this irregularity.
In the mean time, this seems to occur only with a wireless hook up in our tests, and as such, if possible, may I suggest wiring your Airport Express directly, or continuing with your 'quick fix' as described.
As soon as I have a further update I shall be in touch to inform you. Depending on the findings of our engineers, this may take some time.
so there you go, I didn’t want to leave this thread with a false ending, for anyone thats has had or having a similar problem that I did.
