As I mentioned in a previous post, the Apple AirPods Max is one of the more interesting headphones to measure. We've been measuring the AirPods Max since it arrived a couple of weeks ago. We've measured it wirelessly and wired. (We'll be doing a final set of
wired measurements soon, too.) We've measured it with ANC on and off. We've measured it at several different output levels. We measured it with music as the stimulus (using Audio Precision's Transfer Function Measurement functionality), stepped sweeps, continuous sweeps, pink noise, white noise. Here's an example of our notes from just some of the measurements in only one of several AirPods Max Audio Precision project files from the past couple of weeks (each line is a separate sweep/measurement, this one project file having 40 such entries):
Measurement observations so far:
- With ANC on and ANC off, the frequency response is the same.
- From 70 dBSPL to 113 dBSPL, the frequency response in any given seating remains essentially the same.
- We get essentially identical frequency response measurements whether using continuous sweep, stepped sweep, or noise (pink and white) with Audio Precision's Transfer Function measurements.
- Using the Audio Precision Transfer Function measurements, the frequency response with music so far seems to track the swept-sine frequency response.
- Apple's claim of THD < 1% across the entire range (even at max volume) is accurate. With the headphone set to maximum volume, at -3 dBFS (as per Apple's specified test conditions) the AirPods Max's THD peaked at 0.731% at 342.237 Hz. Other than that peak, THD is mostly below 0.1% throughout the measured range.
Following is the Apple AirPods Max frequency response (average of three seatings):
Fig.1 (above): Apple AirPods Max frequency response, average of three seatings.
Someone had asked if the frequency response changes at various output levels (which I thought was a good question). Following are frequency response measurements at 70 dBSPL, 90 dBSPL, 110 dBSPL, and 113 dBSPL:
Fig.2 (above): Apple AirPods Max frequency response (one seating, left channel only) at 70 dBSPL, 90 dBSPL, 110 dBSPL, and 113 dBSPL.
All of the frequency response measurements above were made using continuous sweeps.
Following are the Apple AirPods Max THD measurements at 90 dBSPL, 100 dBSPL, and 110 dBSPL. (I also posted this a few days ago.)
Fig.3 (above): Apple AirPods Max THD at 90 dBSPL (solid lines), 100 dBSPL (dashed lines), and 110 dBSPL (dotted lines).
I'll post my subjective opinions about the Apple AirPods Max at a later date, either in a post in this thread and/or in a video.
The measurements in this post were made using:
