o0genesis0o
I’m pretty sure there is a pressure release vent at the bottom of the earpiecesAnyone else notice the lack of vent in the Aful MagicOne? I'm liking the way it sounds, but the seal is causing slight ear pain on occasions. I'm also a little under the weather, so I'll probably let it sit for a while before making a decision.
Also I got them from HiFiGo on AliExpress. I've done plenty of returns to Amazon, but never AE. Will they let you do it after you open and audition IEMs?
Which ear tips are you using? Maybe a softer tips would help. Otherwise, Sancai tips tend to solve pressure problem pretty well.
