vid
- Jan 5, 2005
Which link do you mean?
In terms of the effect of channel balance on the sound, I and I'm sure others can spot a difference in quality in regular music between a headphone with slight imbalances - the sort you'd expect on any given headphone - and when those imbalances have been removed. You can try this by measuring both channels of your chosen phones, convolving one channel by the difference, then having a listen before and after. (Though I'll admit this depends on the quality of your convolution, of course.)
I'm sure it would be somewhat impractical to intentionally skew the channel balance for a beneficial effect even if there was a benefit to be had. There is, though, the AKG K 340, which are curious in that every pair I've seen measured - two by Tyll and one by me - has had a clear channel imbalance between 2.5 and 4 kHz. I've wondered whether it's by design, consistent wear, or some technical necessity.
